the gears can always let you unlock the best of what you have got, shifting the powerband just enough to make it what you were after.
you wont need to change the belt when you change the gears though. Just put the motor to TDC on 1 and draw a mark on the belt where the mating marks sit on the gears. the new gears will have the mating mark in the same spot.
I think just line everything up at TDC and reference the std markings in the block and timing backing plate etc. Belts can skip a tooth and flop around the crank pulley and when you tensio it back up be a way off where the old markings were. Best go on the block markings and not care about the belt
that's the right way to do it, yet I detected OP did not want to pull lower timing case off as its the majority of the task in changing the belt (done 10ks ago).
in which case you can be dodgey and do it the other way.
myself id do it properly. just sayin'
Ok, So have wasted time and money thinking about the RB25 and 20G setup and leaning on it for all its worth. I want to be sure that walking away from what has been a champion turbo is the right thing to do. Also will give a good baseline for other setups being trialled
So by the end of the day will be interesting to compare:
RB20 RB25
TD06-20G. 8cm 12cm
Cams Std 256/8.5 Tomei
Fuel E85 E85
Both engines run the same inlet and exhaust manifolds. As it is an R32 RB25 it does not have NVCS will be interesting if the better breathing hot side, bigger cams and bigger engine will result in more power then I was making on the RB20
Figured I'd do an update on my setup.
I made 235kw on 18psi, RB25 TD06 20G 10cm.
All you cool cats worked out my intercooler was shit house, you were all right!
I've stuck to return flow as I want it the engine bay as factory looking as possible, but a much better setup.
Ended up taking it for a drive on Monday, left the boost controller on low just to be safe. Low boost was set at 14psi previously, and with the new intercooler it's pumping out 20psi! Crazy how much restriction the old cooler setup made. Pulls like a freight train now too which is great. Also feels less laggy too, win win win!
So thank you for all your input lads :D
Edited by Run-It-Hard
I will need to get it on a dyno soon, needs rego first though (ran out lol).
I ended up finding a HKS type S intercooler kit in Japan and got it sent over. Neat bit of kit, managed to get the return up nice and high too with a bit of moding so I'm all smiles :D
RB20 RB25
TD06-20G. 8cm 12cm
Fuel E85 E85
I'll take a punt and say that the 25 won't wake up down low with the bigger housing, but should shade the 20 between 4-7000. Will be an interesting comparison.
8cm and you reckon it was lazy down low?!
Do you think that's because the turbine was choking at the lower shaft speeds (in that tiny housing) or a different reason?
A 20G shouldnt be lazy down low, especially with an 8cm hey..
I had a 12cm on mine for a month, was so bad lol.
Although it could have had better response with my new cooler setup. Cams might help it out too, dunno. Trent's set it plenty of times that he loved his, he had cams too.
  On 10/04/2013 at 6:47 AM, Frosty said:
▲ id have to agree! mine had an 8cm rear on rb25 and was way lazy down low..12cm i think will make it more doughy and i dont think up top with that much of an advantage
LOL...really? Something very different between our setups then. I was hitting 18psi at 3,200rpm or something stupid and show was over with the thing losing its pull over 6,500rpm. It was mega grunty with the 8cm housing. And that was with cams at 0 and only a 2/3 tune.
I like the way the 12cm drives but on a very rough tune with no ignition the 12cm housing has generally added 800-1,000rpm to response. Would be far easier and nicer to drive with the way it delivers its power.
Will see if we get any of theloss in response back with the changes we made today....the car got pulled off the dyno due to another car needing some urgent work.
Will keep looking for a 10cm housing but think the T67 will go on before a find the right sized housing for the 20G. That will be the real test as I am pretty sure we have maxed out the compressor on the 20G so the question is will the billet wheel flow more with the TD06-12cm vs the T67-25G 10cm . That will be the real interesting test. Smaller, lower flowing turbine with a 78mm cast compressor wheel VS a larger higher flowing turbine with a lighter, smaller billet 73mm compressor with the larger 12cm housing.
I would go straight for the proven 10cm if I had one so ...no other choice then to waste tuners dyno time with my games :)
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
