With the 12cm a bit more energy was put into trying to get it to hold boost. Didn't exhaust ourselves as I dont want to spend too much $ fiddling around when the setups are going to get swapped. Main thing is we get to see the character and idea of response and numbers. But curious that it wasn't anywhere as simple as getting the other combos to hold boost.
This is similar to what I found with the 1.06 tial. Nothing in the Turbosmart instructions worked so I had to design my own setup using the 5 port. Buggered if I would be paying a workshop to diagnose all the issues I have had so far...
Anyway, good luck with the HTA, should be a good thing on the 25.
This :whistling:
Well after some head scratching found a problem with the Turbosmart gate. Will be surprised if its the cause of the boost problem but either way the thing needs fixing as the bottom of the alloy housing is pissing air through the valve stem due to a failed o-ring. Seems to be made of rubber which has naturally hardened and failed. So in theory that would make the thing spike or run higher boost than expected but will see.
just got my rb25 tuned the other day with the td06sl2 10cm, greddy copy, 440cc injectors, aftermarket throttle body, custom low mount steampipe manifold, full 3 inch exhaust.
Car made 268 hp on 15 psi and it started to lean out on full throttle.. and this is my problem now D:
wasn't your tuner able to diagnose this on the dyno?
I can have a guess and say it was your............... wheelnuts? I mean it was on the dyno... why couldn't the tuner work it out? Its almost impossible to guess what did it without getting you to check nearly everything including the wheel nuts, but it would have taken said tuner under an hour MAX.
Argh this R32 seems very resistant to do what it should do. How was the 73HTA behaving in terms of spool compared to the other setups? It's a shame to hear it sounds like it might now get its chance in the sun due to external factors.
Very keen on this also :yes:
Nothing amazing. Nbew fuel system is about finished. Turbosmart parts arrive today. So hopefully over the weekedn get things sorted and get theh thing fully tuned on Monday. Only the 73HTA is already off :) I looked in the mirror and deep down inside I knew I wanted to run the TD06H-25G...ie a Man's Turbo :)
The 73HTA had near identical spool and looked as though it would tune up ok but ran out of fuel. I canned it as wanted to see how the gruntier 25G was going to go response wise with the smaller 10cm housing. Also want to make sure that I have the biggest dirtiest turbo I have on there to check the engien as there is possible there is a restriction somewhere in my setup that is capping power as nothing tried to date has allowed the thing to make the power of the RB20 :(
So need to rule out the fact that my kinder surprise engine isnt somehow a bit ordinary at making power. Its got good bits, Good compression, pressure. No blow by. Tunes up right...we did run out of fuel but it doesnt really make any more power at 20psi then it does at 15psi so ?!?!?!
^ ditto, but I can see where you are coming from. Shame about the resulting what-ifs, but if it spooled well and we know that it is only a few lb/min lower flowing than the 25G (~54lb/min vs ~58lb/min?) then it isn't a bad indicator.
Will see how the 10cm housing goes. If it is somewhere between teh 8cm and 12 cm (makes sense) than I will grab 40-40rwkws through the midrange which given the 25G wheel gives me the sort of power that I am after ...well not being able to put a 10cm housing on the 20G or 73HTA is a killer.
:blink: i made 267kws on pulp @ 15psi...you should be pissing in around 350hp atws...
You need more fuel? E85 Walbro pump, Bosch 1000's and ethanol in the tank... Win.
I think he has bigger issues at hand man...e85 is your answer to everything...:laugh:
stock GTR injectors yeah....invest in IDs...Nissan will love you :D
from my experience, unlike bigger turbos the SL2 doesn't get a huge improvement from e85 anyway...its great on Pulp too...18psi should see you around 280kw ish...
I agree with the above. The L2 20G is a fairly efficient item where it gets close to its maximum flow without the need of E85. Dont need to convert to ethanol to get the right power out of it.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
