Kando Dynamics Turbo
SimonR32
Hello new kid on the block - lets see if you can handle life on the track better than your Garrett and IHI buddies ;)
Got the TD05H-16G installed and running on the car today - went out for a quick road test, on wastegate boost the "1bar actuator" actually held 11psi with no adjustment. With boost control set up it made 18psi by 3700rpm on the SR20, which is pretty much as expected. About 400rpm laggier than the PE1420, but runs 1psi more boost with the same wastegate setup and certainly feels like it has more "grr". Seems like a great match for what is expected of it :)
Seems pretty good
Touch up tune should see boost response even better alil
But you won't get better boost response than the pe1420 as its much smaller even looks smaller than the t25g but should make abit more power up top and midrange aswell keen to see results
I got the td05h aswell on sr but 18g 264rwkw on e85 but full boost by 4000rpm so should be abit more responsive
Yeah if you put much stock in virtual dyno we were seeing ~220rwkw at 18psi on BP98 with the PE1420, quite a lot more on E85... very impressive turbo, but it failed. The TD05 definitely flows more, can already tell at this stage. I don't know that spool will improve drastically.
Fyi to anyone that wants to know. I put the td05 18g 8cm on my rb20. Adjustable cam gears. Forward facing plenum front mount. Splitfire coilpacks. 750cc injectors. Nistune i made 210 with full boost at 22psi by 4000rpm. Then retuned on e85 and made 241rkw. At 22psi full boost by 4k also. Road drive with both tunes. Very agressive with both tunes but i would say it starts with a better pull woth e85.
Hope this helps everyone if there is any unfinished questions. Ill try post a pic of the dyno sheet when i get a chance
anyone know the difference between the t67 t3 10cm anti-surge and the non anti-sure
also i noticed they had a t67 with a t04r wheel
trying to toss up between one of these or one of HGs for a rb25 on e85 either low or highmount ex gate for around the 330rwkw-350rwkw
stay clear from the anti surged covers on the t67-25g, I gained over 800rpm response by ditching the anti surge cover, it was a pile of shit.
It's not a Kando, there have been turbos I've known of for ages which would match of outperform these but are either more expensive or just not what people in this thread aren't looking for.
FP HTA3073 for 350kw and epic response i reckon!
Not a cheap option but i can tell you, after the initial drive in mine with the HTA, ill never use another turbo! Its SO good!
^ Agree'd. I have been using a Custom FP turbo with a HTA82 Compressor wheel for 3 years now, and it is amazing compaired to other turbos.
Its appears that all the caste wheeled turbochargers are all in one boat, and all the billet turbochargers are in another boat with marginal differences between any of them.
That VNT turbocharger hypergear made is probably the only turbo that is different. Might be worth while waiting and get that.
Just our boat is faster and responds quicker :laugh:
i reckon the kando t67 will do same power with same boost as the fp hta but wont match the response. what the fp hta response like to the turbo hypergear are doing with the vnt cause that looks insane
So far I think the HTA3076 has made more than any of the T67s have - I could be wrong, but I haven't noticed any matching 391rwkw on a Mainline or Dyno Dynamics.
The rpm readings from the Mainline were a bit hard to work out but could tell that at 4000rpm the HTA3076 had more than the VNT, albeit not massive amounts more (and again the VNT was on a hub dyno) - and the HTA made more power peak... without the risk of having moving parts in the exhaust stream which could fail. Will be interesting to see how Stao gets on with reliability as otherwise it is pretty sweet!
yea i was going by simons but yes that was on a hub maybe ill push mine up 28 for couple runs on dyno see what it can go for comparrision were thinkin 350 on 20-21 on mainline.
Also agree i think it may run into reliability issues with moving parts it has but its a low bosst pressure for the power its making
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
