Yeah, I'm not sure which one to go with, the TD06H comes with the T04R compressor aswell.
I'm picking out of these 4:
T67/T04R billet compressor - Anti surge - 10cm
http://www.ebay.com.au/itm/Kinugawa-Billet-Turbocharger-4-T67-w-Garrett-T04R-wheel-T3-10cm-Nissan-RB25DET-/291177385706?pt=AU_Car_Parts_Accessories&hash=item43cb864eea
TD06H/T04R billet compressor - Antisurge - 10cm
http://www.ebay.com.au/itm/Kinugawa-Billet-Turbocharger-4-TD06H-TE06H-w-Garrett-T04R-wheel-T3-V-Band-10cm-/281375447822?pt=AU_Car_Parts_Accessories&hash=item4183489b0e
T67-25G Billet compressor - Anti surge - 10cm
http://www.ebay.com.au/itm/Kinugawa-Billet-Turbocharger-4-Anti-Surge-T67-25G-T3-10-cm-V-Band-Housing-500HP-/281375446227?pt=AU_Car_Parts_Accessories&hash=item41834894d3
T67-25G Billet compressor - Non anti surge - 10cm
http://www.ebay.com.au/itm/Kinugawa-Billet-Turbocharger-4-Non-Anti-Surge-T67-25G-10cm-A-R-73-T3-V-band-/291181230987?pt=AU_Car_Parts_Accessories&hash=item43cbc0fb8b
I'm guessing the 4th option would be the most responsive seeing as it doesn't have the antisurge housing. The TD06H being the laggiest of the 4 having the bigger 58mm turbine, but would flow more top end? Does anyone know how a T04R performs against the 25G compressor? Which would be the better option for a street car.
If you're purely looking at the Kinugawa range then on a RB25 you'd look closely at the T67-25G and E85.
You might also look at the Hypergear derivative, evidently his thrust bearing is a worthwhile upgrade - unless Kinugawa are/have incorporated something into their range.
I would like to leave room for 350rwkw
I think the Kando one maxed out at less than that from his testing, but that was with the cast compressor.
That is GTX3071 territory on e85 with much better response.
well the choice is easy...your only choosing from 2
you can't run a66- 67mm T04rcomp wheel with that turbine, unless you like lots of lag, not much power, peaky all or nothing delivery and get flogged by everything
you need at least a 65mm turbine to drive that comp wheel..
history has proved it over and over again..vl rb30 owners where doing stupid shit like this 15yrs ago..
cheers
darren
Edited by jet_r31
figure looks stupidly high for only 98 and low boost. but my t67 is up around 360kw atm on 22psi e85.on song around 4k on road.
car went in for tune on bigger boost last week, but fuel pressure is dropping off above 6k so chucking in walbro 460lph pump to see if that will help with the problem.
yea just bp 98. really happy with results so keen to drive it. should go 400. pluss on e85 and more boost.
but it will stay how it is plenty enough for drifting
Any more info on setup? Cams etc..
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
