Trent do you have any results from SR20's.
I'm buying a TD06-20g 8cm. Hoping i did the right thing =)
I just red all 33 pages of this, Love it =)
Buy the L2 dont get the plain 06 variant.
This car had a GTRS on it (red line) and it lost nothing with the L2, this car has a little more lag than normal as VCT is disabled.
STD SR20 with 264 HKS cams on std valve springs etc..
Yeah I nearly bought the one (HKS mani) in for sale the other day cause I have an old HKS gate to suit, probably should of but i dont have alot of faith in second hand cast parts I cant see before I buy :(
now I will have to weld it onto the housing ghetto style too, doubt i can afford the 6boost low mount atm..howmushizzit??
Actually if i sell my old turbo..hmm
around $1200 + delivery lol :O
cheers for the graph Trent, i rekon one of those will be perfectly suited to a RB25.
You wouldn't happen to have a dyno graph of a RB25 with one of these turbos by any chance??
That is awesome considering it's compared with a HKS item.
How much boost?
How much boost?
19peak, the gate was a little lazy (ebay) so its missing about 20 mid range kw too... as it cracked open @ 15psi.
Thats insane!
How do you think it would go on an 8cm housing or you think thats a dud choice? There are also 8cm IW housings that Kando sell.... Man these things just got back on the map for me!
Thanks Trent, sorry for so many Qs.
P.S. Told you ARTZ!
Thats insane!
P.S. Told you ARTZ!
10cm only for rb25 reckon. 8cm will miss out on too much mid torque and kw. If you got it run with it but if it was mine id use the 10cm.. ive had a few IW gates not perform so until i can confirm it being the turbo or the car i will stick to the ex gate.
Holly shit thats good.
Thanks Trent =)
This must be on e85 tho yea?
Thanks Trent =)
conservative BP98 tune, peak timing was only 9 odd degrees took 12 no dramas..
but being std i was worried about longevity as it gets the shite drifted out of it.
Please comment on this vs a 8cm :(
FOR AN SR.... lol... will the 8cm make it much more responsive or is the extra flow of the 10cm only going to make it better better better?
here some pics of it compared to stock turbo..
inlet is 3 inch but comp wheel is the same diametre as stock just with bigger housing
but baby got back :P
I'm really not too keen on welding gate onto the housing but many do it and say it works fine..
What the biggest comp cover that fits with the standard RB 25 exhaust mani(with a little spacer) is it 3 inch?
and what would the TDO6H-20g with 12cm housing IW housing be like?
anyone have a rough idea with spool difference form 10cm to 12cm- 300-400ish rpm?
cheers
darren
Edited by jet_r31
I'm ready to buy now , What do you guys think of this one, with the SL2 rear wheel, haven't seen this one up there before.
I want a turbo that can do 320- 340rwkw(in a manual) i don't need anymore than that as i will be trans limited, so if i can
knock of a bit of top end flow and pick up spool, then all the better
http://www.ebay.com....984.m1438.l2649
What would a TD06SL2-20 G 10cm external gate do maxed out on a RB25?
you have any idea STATUS?..anyone?
cheers
darren
Edited by jet_r31
    • I've got the rear ones, they're certainly beefy. I need to take them to my driveshaft guru to check over, he's very fussy about the quality of components so I'll let you know if they are made of cheese by a blind man.   Are you in Australia? A mate just had a set of EN26 shafts made for his K20 Lotus by our fabricator which were quite cheap (compared to Driveshaft Shop) so if you can procure the CV's and draw what you need he'd make them for ~$800 for the pair.
    • Had I known the diff between R32 and R33 suspension I would have R33 suspension. That ship has sailed so I'm doing my best to replicate a drop spindle without spending $4k on a Billet one.
    • OEM suspension starts to bind as soon as the car gets away from stock height. I locked in the caster and camber before cutting off the kingpin. I then let the upright down in a natural (unbound) state before re-attaching it. Now it moves freely in bump and droop relative to the new ride height. My plan is to add GKTech arms before the car is finished so I can dial camber and caster further. It will be fine. This isn't rocket science. Caster looks good, camber is good, upper arm doesn't cause crazy gain and it is now closer to the stock angle and bump steer checks out. Send it.
    • Pay careful attention to the kinematics of that upper arm. The bloody things don't work properly even on a normal stock height R32. Nissan really screwed the pooch on that one. The fixes have included changing the hole locations on the bracket to change the angle of the inner pivot (which was fairly successful but usually makes it impossible to install or remove the arm without unbolting the bracket from the tower, which sucks) and various swivelling upper arm designs. ALL the swivelling upper arm designs that look like a capital I (with serifs) suck. All of them. Some of them are in fact terribly unsafe. Even the best one of them (the old UAS design) shat itself in short order on my car. The only upper arm that works as advertised and is pretty safe is the GKTech one. But it is high maintenance on a street car. I'm guessing that a 600HP car as (stupidly, IMO) low as you are going is not going to be a regular driver. So the maintenance issues on suspension parts are probably not going to be a problem. But you really must make sure that however your fairly drastically modded suspension ends up, that the upper arms swing through an arc that wants to keep the inner and outer bolts parallel. If the outer end travels through an arc that makes that end's bolt want to skew away from parallel with the inner bolt, you will build up enormous binding and compressing forces in the bushes, chew them out and hate life. The suspension compliance can actually be dominated by the bush binding, not the spring rate! It may be the case that even something like the GKTech arm won't work if your suspension kinematics become too weird, courtesy of all the cut and shut going on. Although you at least say there's no binding now, so maybe you're OK. Seeing as you're in the build phase, you could consider using R33/4 type upper arms (either that actual arm, OEM or aftermarket) or any similar wishbone designed to suit your available space, so alleviate the silliness of the R32 design. Then you can locate your inner pivots to provide the correct kinematics (camber gain on compression, etc).
    • The frontend wouldn't go low enough because the coilover was max low and the upper control arm would collapse into itself and potentially bottom out in the strut tower. I made a brace and cut off the kingpin and then moved the upright down 1.25" and welded. i still have to finish but this gives an idea. Now I can have a normal 3.25" of shock travel and things aren't binding. I'm also dropping the lower arm and tie rod 1.25".
