I keep telling you fool!
That rear wheel, housing and gate combo Simon is running WORKS. It is the same rear wheel and housing you have, now get the gate to match! Tial MVR 44mm.
I'm fairly certain that battery also runs the game Tial 44mm MVR
yeah battery has mimmicked your setup part for part..but you are both running a t67 im not..I originally told scott to get the 44 as well now he want let me change my mind..lol
Im not running EBC so correct gate choice is more critical..but im probably over thinking it.. dont matter I will just get the MVR cause it comes with a spring pack and if its right , well I was right all along. But if its wrong I will just blame Scott... ;)
ed...Simon are you using the water cooling on the gate, if so which pipe did you run it off?
What spring and EBC u use.. Would love to know how well it holds boost without EBC..
that will be needed to be done anyway as it only comes with a 38mm ext gate fitting, modding it to take a 40 or 44mm gate isn't that difficult and should't cost much to do and will be something that i'll do with my setup.
however with that being said, i am very curious to see how Jez's setup turns out and looking forward to his results as he is using it with a 38mm gate.
im not just talking about welding a new flange off the ext pipe.
u need 2 cut into the manifold die grind all the shit out and weld new section in there.. anyone with a clue can do it..worth the money trust me.
Yeh i didn't intentionally copy simons setup, it just sort of happened... pretty sure simon runs the same EBC as me profec b II. I bought the gate and manifold together used for $1100 so not %100 sure on the spring but I think its 1 Bar..
On the subject of cheap manifolds I have had bad experiences in the past with the Stainless items they crack sooooo easy its just not worth the hassle and personally i wouldn't trust an ebay china gate either.
Don't worry about not running a EBC, just get a gate a few psi less than what you intend to run and then control the rest with a Turbotech $35 job. You will be surprised how well it works, I would run this if I didn't want switchable boost :)
Water cooling for the MVR, not running it... I don't see a need unless it's a full race car maybe. More of a gimmick
I use a 1bar spring and Profec B Spec II (only because I got it cheap second hand, I would rather a blitz dual solenoid)
Did some testing using the Profec B as a boost readout.
Loading it up to 3000rpm/80kph in 4th then going WOT I see 15 psi @ 3400 and then fullboost 20psi @ 3600.
Also had a misfire issue a while back and had to go from 0.8 gap to 0.5 which solved the problem.
So pretty much exactly the same as mine...
Funny how even on the same type of dyno on the same ramp rate mine appears so much lazier :pirate:
Sorry this is not related to Kando turbos but while your on the topic of wastegates..
Simon, what spring(s) do you have in your 44mm MVR and also; if ur ebc is set to 0% does it boost at the spring pressure till redline or does it creep up a little?
I bought a 1 bar 44mm tial and i hoping it lets my gt35 run 18psi and no more.. will be running poncams too if that means anything in terms of wastegate flow?
Im kinda scared that if it spikes or creeps past 20psi i will have to change the wastegate to a 50mm TS :( I guess we will have to see!
1bar spring... Holds 1 bar :)
Isn't what boost you want to run + rear housing size the main deciding factor with how to choose the gate size?
I dont think you can have too much gate?
Someone correct me if I'm wrong..
well i thìnk you could be wrong. Too much gate will release too much pressure upon opening and cause boost drop..if you have an EBC it will quickly compensate for this but if you dont the pressure is gone and wont come back till the gate closes again..
You need the correct size gate to release the correct amount of flow to maintain boost...which is why i was undecided between 40 and 44mm as I dont know how much power this turbo will make on stock mnifold.. Was presuming 260 to 280 but some are saying it will make quite a bit more..
Plus the 40mm gate is 330 the 44mm is 380 so Im with snozzle on price being a factor...but 44mm tial comes with 7 different springs so I will get that so i wont need an EBC :thumbsup:
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
