anyone got a result for a stock rb25 with a t67 on pump? ive got a few mods like 6boost, tial gate, step 1 tomeis, 1000cc injectors, haltech.. Im really shooting for 300rwkw... achievable?
329 @ 19psi about 345 @ 21psi.
i reckon ive posted around 5 or so setups over the years. (do a quick search they may pop up)
I went to ATS in adelaide today to get some longer studs for a 10mm spacer plate. Bill said he had , had a lots of Kando dynamics
turbos in there, as S@J automotive apparently(a big subaru shop), buy a lot of them for suby upgrades. He said they where genuine
Mitsubishi internals, but they can be a bit sloppy in assembly at times, with oil seal clearances and sometimes the centre bearing oil feed holes haven't lined up with the oil feeds. Basically he said they where a great product just let down a bit with quality control and its worth getting them checked before putting them on and you should get a long life out of them
cheers
darren
Edited by jet_r31
So why is everybody being soft and using the T67 rather then TD06-25G? Cant imagine there is going to be more then 200-500rpm in it and the hotside would surely flow better and be nicer to tune. I think when the time comes im going to give the 25G a go with a 10cm housing
You mean the td06h or the td06?
IMHO the T67 hits the spot as is, id use the H on a rotor or stroker but not a pissy sub 3L motor.
haha @ soft, want a race :nyaanyaa:
From what I have seen a TD06SH-25g is a fair bit laggier with not that much more top end, so not really worth it.
But hey, maybe it's time for a T88 :pirate:
Edited by SimonR32
Ordering the t67 this week finally, I emailed him and he gave me 10% off, so i think it was $837 delivered.
Simon - my old account (cupcake) shit itself this is my new one, im keen to see my results against urs with my haltech and step 1's
i sent old mate a message regarding the td06-25g
i got this in reply, anyone go thoughts on the anit surge fronted td06-25g as opposed to the t67-25g?
Hi,
Here is the link for TD06SL2-25G turbo with 10cm turbine housing.
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-4-TD06SL2-25G-T3-V-Band-450P-/270800154553?pt=AU_Car_Parts_Accessories&hash=item3f0cf26fb9#ht_2323wt_1139
this turbo is on 5% off now and we offer extra 5% discount if you can pay through paypal to save ebay handling fee.
So total is AUD 854.03 x 0.95 + free shipping = AUD 811.3.
By the way, if you can consider another cover,
We can offer special price as we wanna clean this cover.
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-Anti-Surge-TD06SL2-25G-T25-Flg-/270798756146?pt=AU_Car_Parts_Accessories&hash=item3f0cdd1932#ht_2339wt_1139
we can change the turbine housing to 10cm as above for you as well.
Total price is AUD 680 to door.
Regards
Eiji Takada
Well I have both in a box and going to give the 25G a go before T67. From the results I have seen on friends cars is the 25G catches the T67 at 4,500rpm and powers on to make 20-30rwkws more. This was from similar cars with same tuner. But was a long time ago and people are making more from setups these days so would be interesting. I will have my built motor by xmas to trial with. Will be happy with 320 from T67...they just dont seem to make power after 22psi where rhe 25G can squeeze about 24psi into them and make 350rwkws...not sure how strong my first diy engine will be and how much boost it will like
Has anyone used one of the TO4R turbos they offer?
Looking to use one these on a 4.0L xr6 engine in an r34 GTT.
Want to make a solid 450kw.
Recommendations anyone??
Not fussed about manifold I'll be fabricating my own. Prefer external gate.
And.... Now im confused on which route to take, the td06-25g with10cm and anti surge or the t67-25g..... :( help me!
Same aren't they except for comp covers?, so i guess it comes down to how much clearance you have with your manifold, if you have plenty
i'd be going the 4 inch cover, if you have a standard mani get the 3 inch.
$680 is not bad, he still want $750 delivered for that one with 10cm usually, i got him down to $720 with 2.
cheers
darren
They are not the same. Forget ported comp covers which were never offered by Greddy so I know nothing about...the T67 is smaller on the hot side.
Following are pics showing the size difference in turbines that I posted earlier in this thread
TD06L2-20G 8cm
T67-25G 10cm
and an TD06SH-25G 10cm
...have a look at the following pics to get an idea of the difference in exhaust wheel . The TD06SH turbine flows more then the TD06L2 turbine and whilst they have the same compressor, the SH wheel poses a lot less restriction.
As you can see, the SH turbine is a fair whack bigger then the L2 wheel.
I'll keep a eye out on the results... More than happy to change my turbo if something is found to be better :)
But saying that I don't really need any more power :whistling:
Edited by SimonR32
Yeh i know they are different Roy, but i think the poster was refering to the TD06 SL2 25G that kando sell,,and they are the same, the comp covers
are only different
He will do this one
http://www.ebay.com.au/itm/270794579581?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
For $664 to your door this week if you pay through paypal
I want to buy tommorrow, not sure if i should buy that one, or this one
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-Anti-Surge-TD06S-25G-T3-V-Band-/290603882502?pt=AU_Car_Parts_Accessories&hash=item43a9575806
Thoughts??, i want to put it on a standard manifold. One just looks prettier from all i can tell, i don't need to turn the earth power wise, would be happy
with 320ish rwkw on a standard manifold,on pump 98 with water/meth injection hard to ignore the cheap one for the price though.
cheers
darren
    • Thanks for posting, your engine bay looks tops. I'm fairly sure you posted the wrong video though, I think you were supposed to upload the one from your "private test road" where it's banging off the limiter with the gate open?
    • This is something to be careful of. I did a bit of digging on the NM35, as I spend a lot of time on near brand new cars and CANBus related stuff, which uses the same "OBD2" plug for a fair chunk of making my life easy. The NM35, does NOT support OBD2. The data pin is actually on Pin3, which is a manufacturer specific pin, and requires Consult3 to connect to the NM35. Your low voltage, is either because the NM35 doesn't have 12V to the constant power pin on the J1962 (OBD2) connector, OR, it is attempting the standard comms, (CanBus, K Line, etc) and can't see any voltage on those pins. Some people have had success accessing SOME data from the vehicle on OBD2 specification, using a module that supports KPW. My assumption, like Duncan has stated, it will likely actually be JOBD, where there is some cross over with the OBD2 and JOBD standards. Note, lots of "OBD2" dongles, do NOT support KPW, which is what you need for a lot of Japanese vehicles of this era (And even up until recent years!), EG, Subaru, Suzuki, etc.    The end of this thread is probably worth a read, as some people did find a way to get a display up in the NM35 recently, looks like someone implemented all the stuff needed to make it work. (The right protocols).
    • Depending on the purpose of the car, and how much more fabbing you want to do, and what clearances you have, you could look to raise the motor, which will raise the front diff up. Likely would mean altering the chassis rails etc etc, hence the more fab work you'd need to do. However, this can create issues, not just in clearance with everything fitting under the bonnet, but you've also raised a LOT of weight up in the car, and this will DEFINITELY alter handling characteristics (But, so will how much weight you've already added to the front end). You'll also have to deal with the fact the gearbox to rear diff is now out of alignment too for the tail shaft, and alter the angle of the diff, or deal with a bit of potential vibration. Raising the motor an inch up, is effectively the same as making the whole car sit higher by not lowering it as far. So one inch higher motor, theoretically means you can drop the car an extra inch lower, and maintain the same angles in the CVs. Again, depends on the purpose of the car. If it's a just cruiser on the street car, maybe won't be an issue. If it's meant to be a time attack car, I can see you not wanting to raise the motor. This is just for you to ponder as an idea.
    • Have you not seen geospy.ai? It can now give GPS co ords to within a metre from a photo, even if it's a random photo you take inside. Supposedly at the moment only the government/law enforcement has access to that... Supposedly...
    • I've got the rear ones, they're certainly beefy. I need to take them to my driveshaft guru to check over, he's very fussy about the quality of components so I'll let you know if they are made of cheese by a blind man.   Are you in Australia? A mate just had a set of EN26 shafts made for his K20 Lotus by our fabricator which were quite cheap (compared to Driveshaft Shop) so if you can procure the CV's and draw what you need he'd make them for ~$800 for the pair.
