yes, but hazzard a guess I would say 280-290rwks max on 98.
would have awesome snappy power on a 25 though
yeah thats what im hoping, if you have to get a new manifold though it would be the 67 for sure..
I tried to fit my t67 on the stock manifold just to see if it would fit but it was hitting engine mounts and A/C lines looked like alot of work and bordering on impossible.
Are you going to plumb the gate back into the exhaust?
See what happens..might try a screamer initially just cause I never had one before..lol.. Is yours..??
there was that T67 that had the smaller comp cover...they dont have any for sale now..
yeah so keeping in my mind on an rb25 you will ideally want the 10cm(.73) rear on all EG variants..all you really need to know is 20g for low mount or 25g for top mount..everything else isnt really too important..
Just trying to simplify it cause there is just too many variants...
It will be great to see the 20g and a gate hung off the stock manifold, with all due respect I think it will give hypergear a real run for his money.
It must be said tho, if you are looking for the simplest street orientated option I would stick to the HG. Being externally gated and proven capable of very high flow I would want the Kando for anything that will do some serious track time. No disrespect to HG but I would say for a hard tuned motor the Kando's will be a little more resilient to EGT.
Yeah that's why I'm going to give it a shot it going to be street driven but also taken down the track a fair bit
Yeah thats the thing, the HGs are great these days but we have seen they do get hot. Im confident the 20g will give the current good HGs a very good run for their money for spool/power but will definitely handle the heat a lot better.
The benefit to the HG is having it bolt up to most of the expensive stuff (manifolds and dumps).
GL, I rekon you will have a kick ass setup.
Haha yeah DVS jez kit a off the shelf kit I couldn't get a off shelf kit for rb25 in a Vl so I bought a vlt kit and drop saw and away I went made my own
Gtscott how'd you blow microtech wired up wrong?
You need to be careful with the bloody thing, its pretty weak electronically. What I did was short the ground on my VCT solenoid which is plugged into the vactory ecu. This caused a 12v spike to the stock ecu which is only earth switchable so the stock ECU spiked just about everything and blew its fuse.
When the stock ecu spiked it send a spike down the CAS trigger which the microtech piggyback's onto which fried my injector drivers.
I now have spark but no fuel. Microtech were pretty good about it though, should be able to fix it under 200 if I cant fix it myself. I think its likely to be the earth track for the injector drivers so ill just solder a wire in myself (havent opened it yet).
Careful not to over voltage any of yours inputs coz they do not like it lol.
probably a good thing, microleb for the lose.
ROFL imagine an army of microlebs! Shu Microcuz's! (nobody take offence im a big bad dirty wog myself)
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
