If the motor is happy revving there then I dont see why not. The torque and power character of the setup would influence the load on the motor, there is no denying that. It just might be as happy spinning to 8 as a different setup would be spinning to 7.
The forces created by an identical stroke/bore motor revving to those speeds is identical if all the same parts are used, the torque is obviously different though.
I guess what I was getting at is 8.5k is getting very close to the limit where stock rod bolts etc let go if held there for extended periods of time.
Edited by Rolls
my r33 will be going back into trent(status) soon, hopefully before christmas. my t67-25g setup has been proving very good, no issues yet except for my gearbox. trent, if you read this :P the gearbox shit the tin 2 weeks after the dyno runs so im going to guess it was slipping when tuned, and also the converter is a bit spongy and needs a rebuild(checked by knox automatics). ive been told the solenoids are fkd, the clutch drum for 3rd/over drive is worn out, and the band needs replacing haha. Anyway, i have just bought myself a fully manualised ford c4 street strip box brand new from rocket to go into the car, along with a 3000 stall converter, and a b & m megashifter. i have changed i/c the pipework again since the last tune(only made 255rwkw) and planning on going 4" inlet and moving the afm into the intercooler pipe. ive also heat wrapped the exhaust, sorted out the manifold flex issue and bought a turbo blanket. hopefully this time round, upping the boost to around 20-22psi i can make the 300rwkw i was hoping for.
looking forward to your results.
what other mods do you have?
inj/manifold/gate/ etc.
Goodluck with the C4 man!
My brother uses one in his Sigma but its a bit rough for my liking.. Not a brand new rebuilt job just a used one with a stally and shift kit.
Personally I would have gone for a 4L60 (turbo700) but thats just because im scared of hard shifts lol.
How much did the prebuilt C4 set you back and rekon it would be any good for circuit work or drag only? Shift quality I mean.
if you look back around pages 25-30 of this thread u can see my original build. but yeah, all suporting mods, 700cc inj, walbro 255lph pump, stock intake(this is for testing atm, no-one else has done a setup with the stock plenum and this turbo as far as i know), XSpower highmount - wouldnt suggest these, on a hot run, the manifold buckled and needed extra bracing, umm power fc,3" mandrel stainless exhuast all custom made, z32 afm, blitz suspower pod, 44mm gate, turbosmart plumback bov etc etc. i might change the injectors before a re-tune aswell, they are only flowed stock injectors and i dont know how good they are.
cant say how much i paid for the gearbox ;), but you wouldnt get change from 5k, but it depends on what version you buy, there is 3 of them.
i will put it back on the dyno with the manifold its got for now, the gearbox has kinda chewed up the funds i had ready for buying engine some nice spool internal engine parts, and replacing things i had problems with haha. but i will be changing to a 6boost in future, they are proven items and worth the extra cash. the external gate im not sure what brand, i bought it from the USA for about $150 aus + post, and surpriginly, ive had no boost creep and it holds shut until right on 17 psi, so its doing its job none the less, although im taking the 17 pound spring out, and putting in a 12 psi and going to run a dual stage controller so i can turn it down on the street.
Edited by OMY31T
Running that little boost will test out the wastegate's capabilities
certainly will, wether or not i run as low as 12psi im not sure of, being 44, it should be capable of running as little as 15psi, i just dont want to be running a min of 17 all the time and up to a max of say 22, id rather wind it back to a tidy 220rwkw for day to day driving if i can.
Is that on a stock JZ zeb??
my gate came with 7 different springs rated up to 25psi..
thinking I'll just get target my boost with springs and not worry about any controller..is this a good idea??
what are the disadvantages (if any) of not running a boost controller, apart from not being adjustable on the fly...
bah,, pansy...my BW setup will have a 2 bar spring in the gate lol
whats the point of having 2 bar on the street? roads are not made for racing, nor good handling, ill keep my 300+rwkw for the strip.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
