Yeah, I know mine will be slow around town, But I dont mind, I dont go about doing silly things on the roads any more.
+ I want an old school Jap style build...you know a few years ago when GTR's etc were cool when they had T51R's or T88s etc
haha..thats mental..
well you be happy to know my car is all good and running now, spent all weekend putting it back together and im absolutely rooted..everything that was busted is fixed, so its in tip top shape now and ready for bigger and better things..
thing is Ive been real tempted lately to just get a gcg top mount mani and t67 as well.. :whistling:
im trying real hard to stick to my plan..really I am but its hard and battery didnt just make it any easier..
I reckon just use what you already have and see how it turns out.... you can swap a high mount on later lol
haha nice work... I was very jealous that you had that much traction in 2nd in the first video. The second one made me feel a little bit better :P
First video I lifted on the gear change, second is flat :)
Are 33's known to have more grip?
My old 32 had stock rb25det @190kw, stock VLSD(pretty tight) buddyclub coilovers and 255/40/17.
My 33 made 200kw before the t67, runs a kaaz 2 way with the same buddyclub coilovers on 595ss 225/45/17 and Got way more traction than the 32 ever did.
I guess the 4.1 vs 4.3 diff ratio makes a difference here too.
Edited by battery
Your neglecting one specific dyno sheet with a back to back result. Status posted a back to back result for a HKS GTRS (the god like 250rwkw turbo on a RB25) vs a TD06SL2-20g T3 10cm. OK it was not on an RB, yet it doesnt mean the GTRS is better suited to the SR and the 20g is not does it?
The 20g traced the character of the GTRS right till the GTRS peaked and then the 20g kept going till 300kw.
What more could you want than that? If you could expect the results to be 'similar' on an RB25, that would say the 20g would have absolute balistic response with 300kw? Isnt a 300kw GTRS what we have all be savouring?
Just doo eeeett.
You would think an RB20 with its smaller exhaust pulses reveals the flaws in turbos. My car back to back with a very similar car with a GT-RS showed the 20G is the better all round setup...though in this comparison you have to remember that the 20G was a full maifold and gate setup vs the bolt on GT-RS...and I run a tad more boost but a general picture is still painted
So personally i think the GT-RS is a pretty crappy turbo if for all its "technology" etc etc it cant match a truck turbo for response or power :)
They aren't exactly back to back tests though. One is a GTS-4 and one is a GTS-t so they are different cars which would have slightly different setups. The GT-RS is running less boost and according to the dyno sheet is actually a GT-T highflow, so i'm guessing it is using garrett GT2871R 52trim internals in GT-T housings and i would also assume that it would be journal bearing not BB like an actual GT-RS.
EDIT!!
And there is something else up with that "GT-RS"; Because my CA18 (with a GT2871R 52T) is reaching full boost sooner and is making and extra 15-20kw pretty much all the way through the mid-range and it's a 200cc smaller engine.
Edited by D_Stirls
yeah i am, i was just stirring Scott again... :thumbsup:
well i do keep considering top mounting it but meh that means buying more stuff and im sick of buying stuff, i have everything ready to go now
I dont think i will need to swap it anyway it should boogie ..
EDIT!!
Thats a difference in motor character more than it is something wrong. CAs seem to love boost and airflow, they arent shy and RBs have a set RPM that they come alive. Very different character, its still an RB vs an RB which makes it relatively fair.
Why not just refer to the true back to back job on the SR20 status showed?
Was there a graph posted, i missed it if it was.
I agree that the GT2871R (GT-RS) is not the best matched turbo it's a fair bit better that the next step up in the GT28 range though the GT2876R.
I would love to see what a 52T GT3071R with the cropped 56.5mm turbine would go like on a CA or an SR, as it has the same compressor but with a turbine that will allow to compressor to hit it's straps. I would have through it would behave very similar to a TD06SL2-20G. I'm surprised that the 20G is as responsive as the GT-RS as the heavy side of the turbo (the turbine) is a fair bit larger than the GT-RS. Having said that if it was an 8cm^2 turbine it's effective A/R would be smaller as well at around 0.57a/r, which would offset the weight difference slightly.
All in all on paper the TD06SL2-20G is a much better matched turbo than a GT-RS/2871.
Your missing page 33-34 mate, Trent pulled 302rwkw with a 10cm 20g kando on an SR and back to backed it against a HKS GTRS.
Buy the L2 dont get the plain 06 variant.
This car had a GTRS on it (red line) and it lost nothing with the L2, this car has a little more lag than normal as VCT is disabled.
STD SR20 with 264 HKS cams on std valve springs etc..
The cars run the same cooler, the same exhaust, mine a Power Fc and the other a remapped std ecu. It was 100% a HKS GT-RS, not a Garret, forget what the dyno sheet says. Yes it is a GTS4 but run on a rwd dyno. And two different tuners, mine Racepace and the GTS4 Dr Drift
Yes its running less boost, and perhaps a few degrees less ignition (perhaps, but its possible my tune was the more conservative as it is a track tune so a few degrees short of what you would run on the street). That all said, the general picture is the same.
Also, your plot is a different type of dyno, a different dyno so even more variables to consider. I know my car made 260rwkws on a Dyno Dynamics with the same tune, hell, probably even the same tank of gas :) So I was down 15kws on the Mainline dyno
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
