Maybe he will see full boost by 4? Wouldnt that be better?
I mean the 20g is a 300kw compressor, not more. The L2 rear wheel can easily flow 300kw, so that all balances out.
That TD05H-18g we tuned the other night made 526 NM at 4400rpm, and the blowoff didnt blow open :nyaanyaa: . Only tuned to 14psi but making full boost in the 3s and Jez said it was starting to boost in the 2s. 207rwkw @ 14psi, we lucked out on the Z32 and had to go back to the stock SR20 AFM.
Power is one thing but delivery is King.
Fo sho, ill get it out of the car on the weekend. Jez is up on the coast and were in Sydney, so effectively got home some time after 3am and didnt think too much about the graph lol.
We did try to tune beyond the stock AFM resolution but werent having much luck with some ping becoming evident. AFRs were in the low 11s and timing close to 20 up top (from memory). Not sure if its a +T thing or if we could have done something different.
It is very VERY fast, the number is very deceiving (me being a 200kw SR veteran afterall). Might run it up on another known dyno down here.
When I was buying mine I spoke ro kando and he said that between the two the h is a better turbo for a 20 and the ls2 would only come on about 200 to 300 rpm quicker so I got the h all depends on your setup. I bought mine on sellers recomendation which he would know his product better then anyone. Mine is back on the dyno tonight I'll post results . Any bigger turbo in most cases on a 20 will not see full boost past 4 grand just can't flow enough below that to spool the turbo. Yours being a high comp motor will bring it on a bit quicker but can't handle high boost otherwise it will detonate.
Interesting, this was tuned on petrol? Sounds like a good result anyway, some vid footage would be good too :) How does it compare with the old fabled +T? I bet it goes well, too!
With only a 20kw jump it definitely feels more like a 30% increase everywhere in the rev range. Literally shitting on the old T28 based setup.
FYI this is still the same fabled +T, just with the bigger turbo and the Jez-meisters tune.
Will get some video when I get a chance, need to be warey of where I drive this car lol.
EDIT: sorry yeah was tuned on BP98
How many 98 octane tunes with the T67 25G are in this thread..i can't remember is it just the 1 x r33 with converter, what pages are the dyno sheets on if theres others?
cheers
darren
Yeh pretty much... That black chaser with the 1jz that i posted a while back made like 305kw, 20psi on bp98.
You would think after 60 pages of discussion there would be some more results lol...
I don't know which turbos you are talking about the Kandos being half as much as, but fwiw we acquired a S300SX 83/75 for $100 more than a Kando T67 would have cost to land, and the same goes for genuine Garrett T3/T60-1s and other things... given the failure rates I've seen for the Kandos have been higher than for the journal bearing Garretts and Borg Warners over here (for whatever reason) its hard to sell them too strong when you KNOW you can count on the Garretts etc.
I am impressed with them, but try and stay realistic at the same time.
lol everybody is still spending double on fail-me-do brand names :P
for me the Kando's continue to Work.
fixed :P
Don't know that i'd say wow, but they don't break too much and results are on par with the genuine stuff.
I think they're the best bang for buck turbos on the market at the moment and by a long way too.
Edited by badhairdave
Honestly not sure what is happening in the NZ yet I am still waiting to see one fail here. They are particularly common on the Subaru and homely MHI based forums, yet no failures from what I have seen (other than the one you yourself posted Lith, however I am of a different opinion on that one).
I'll honestly stand by wow, they are a very inexpensive option and can be sought in so many specs you can use it in place of so many OEM applications with minimal (read acceptable) hassle. Take it this way, I have a GT2860RS on my current motor, I can order nearly any spec kando in a housing configuration that will bolt straight on right down to the front houisng hose connections. I can also order it with any fitting kit I like without additional cost. You do not get that when you buy a garrett.
They are also roughly half the price of a Garrett before you tac on the GCG tax (fking massive in itself), plus everything else they sting you for. Housing options, extra. Actuator, extra. Any level of custom request, much extra.
Email kando and ask for something they do not stock, he will offer to invoice you and will list it in his shop for you to buy. The factory will put it all together for you as you request and send it out. He has even agreed to port housings for me in the past, to whatever spec I request.
Yes, wow.
Whats going on in NZ is I know enough people here to hear the good and the bad, not everyone live on forums. I'm not saying its BW EFR levels of failure, but more frequent than your typical Garrett/Holset/BW turbo so far.
In regards to "not wow" I think he was talking in regards to outright performance, not price. The price is really good for what you get, but its still "for what you get" so far.
And I did not specify what I consider to be wow :P So its Wow.
Obviously you cant be tooooooo impressed with the performance when they are meeting the expectations of the items they are made to replace lol. Oh wow it did what it was meant to!
Ahhhh sigh im freaking bored..
Fly over, have a rum with us.
I'll check with my mate who had his need a premature rebuild was a TD06SL2/T60-1 hybrid... can't remember what the problem was but I am pretty sure I remember him putting it down to "Thats the risk you take when you use cheap stuff", got it rebuilt and it was fine afterwards and still uses version 2 being philosophical about the fact it was still not a hugely expensive exercise.
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
