A full 60-1 is a T04S, nothing special... However I dont know why Kando trys to sell so many of them or in what application they would work well.
Interesting I guess... Im sure there are still old tech Garretts that whoop ass and take names.
Lithium it seems to me your talking about the 60-1 which is not a trust spec turbo but a cheap Garret spec may e the kando Garret spec turbos ate no good but there has not been a problem yet over with a trust spec turbo hence why this thread is about 60 pages big
Are they straight up component failures Lith?
or other factors involved?
from what i have been told, dumb assembly problems and sometimes the clearances are a bit ho hum , the actual parts used to make them are very good
so your basically taking your chances whether you get a monday or a friday turbo, unless you spend up to $200 ish getting them all mickey mouse.
apperently S@J who do subaru work here in adelaide have bought hundreds of them, so i was told.
cheers
darren
Edited by jet_r31
How many 98 octane tunes with the T67 25G are in this thread..i can't remember is it just the 1 x r33 with converter, what pages are the dyno sheets on if theres others?
cheers
darren
got heaps, average output is 300-330rwkw on 98 std cams and btm end, 340-360 with decent cams.
Fo sho, ill get it out of the car on the weekend. Jez is up on the coast and were in Sydney, so effectively got home some time after 3am and didnt think too much about the graph lol.
We did try to tune beyond the stock AFM resolution but werent having much luck with some ping becoming evident. AFRs were in the low 11s and timing close to 20 up top (from memory). Not sure if its a +T thing or if we could have done something different.
It is very VERY fast, the number is very deceiving (me being a 200kw SR veteran afterall). Might run it up on another known dyno down here.
with 20 degrees it would want to be e85?
So I'm guessing it's going onto a 20 why you going the ls2 and not the h? I have the td06h-20g external gate and see full boost at 4500
VVV that's why
Maybe he will see full boost by 4? Wouldnt that be better?
I mean the 20g is a 300kw compressor, not more. The L2 rear wheel can easily flow 300kw, so that all balances out.
Power is one thing but delivery is King.
Ok , my reasoning for picking the l2 is for the earlier spool , the car it's going in will be used for all different forms of motorsport , i'm not interested in the final number it shows on the dyno more so how it comes onto power and when . Not taking anything away from the H , just after a lengthy discussion with my tuner he/i/we thought the l2 would suit me better :) . The whole 20 setup is only temporary while i'm building the new motor for my car (rb** , i haven't fully decided between 25 or 30 yet , that's pretty much all i'm waiting on for the other motor to be ready) if the turbo fares well i might even put a 10cm housing on the back of it and use it on the other motor for a lil while :)
Boost??, i know i did my head in last night and went through the whole thread, think one post you quoted 345rwkw on 21psi on 98 and 329 on 19psi
edit page 39
Would it be to asking to much to post up some of those big power 98 (standard cam) graphs, to see the power under the curve?
cheers
darren
Edited by jet_r31
You will have to confirm with Jez but I am pretty sure it was up there. It was happy at 17 and pinged at 21, so its somewhere inbetween there.
The turbo was really cruising along, I doubt the charge temp is up there at all (14psi bleeds down to the 12s)
Ok so went on the dyno last night made 242kw with major wheel spin from 5 grand on so can't get a proper reading. There is a restriction somewhere holding it back as well will be playing today im thinking wastegate pipe so is jez so more fab needed will be opening it up to 40mm id pipe and further down the exhaust. Setup is stock rb20 with td06 running 18 pound and your usual breathing mods seeing full boost (on the road) 1st 4800 2nd 4700 3rd 4500 4th 4300 there abouts anyway didn't bother with 5th on the dyno always reads less
Update on my tubro and motor... Did 2 full days of track work at Track Battle in Perth
Ran 20psi and revved anywhere from 7500-8000rpm and it's still loving life!
For anyone counting I also managed a 66.7sec long track which I think is fairly respectable :)
Well dome Simon and good to here still going strong
How was traction...did you get around to changing anything
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 馃ぃ, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
    • This is mine, works a treat for the cars, suction is good, I use the Bissell clean and protect stuff I have found giving it a good spray and light scrub with the soft brush on the head of the nossle for carpet, and a rub with a microfibre for cloth seats and cloth door trims, prior to another quick spray before vacuuming it up works the best @GTSBoy You would surprised on what it gets out of carpet and seats that actually "look" clean, I recommend that you test drive yours when you have a little time to kill, then post pics of the muddy looking water that I believe you will find
    • I think even the "commercial" capacity ones that you would hire from supermarkets etc wouldn't have the capacity to do all that much in one go. I will go through half a dozen tanks of solution and dumps/rinses of the waste tank for one little 2 seat sofa. Or similar for one 6 footish rug. That's the price you pay for something small that only takes up a bit of cupboard space, instead of something that takes up the entire laundry cupboard or half the shed.
