love the thread it a long read but jam packed with good info...........quick question
hey i got a 2j with cams,upgraded valve train,wiseco's,manely rods head ported ,link g4 etc................i had a pair of kando td05/20g turbos which i sold brought them to run on a stock 2jz now ive built a motor im looking at getting the 800hp plus mark.........what do you guys think about a pair of td06sl2/25g with 4 in cover and a 8 cm rear turbo's i can change housings to 10cm/12cm there are option in rear housings................be to laggy,will i get 800-1000hp out of those td06sl2/25g's
25g x 2 will be too big IMO for a still 3l jz unless you're turning 9k rpm
Td06h-20g with 8cm rear will be monstrous on e85 turning the jz to 8000
Might not quite make 800rwhp. But will be bull shit fast
Also how did the 2j go with the td05-20gs?
Full boost / power erc?
im not using the td06h/25g im using the td06sl2/25g
's
never got them running i changed my mind and wanted to build a motor...............the sr boys are only making 220kws with these td05/20g is on par with a gt2871/6 nearly most 2j boys pull with gt28's are 420kws with ripe fruit on the motor
i got 272 cams,shimless buckets etc it's built to rev
Edited by stocker
here are the compressor and turbine wheels for the td05/20g and the td06sl2/25g not really that much of a differance in them few mm's
TD05/20G 3IN ANTI-SURGE COVER
Compressor wheel: 52.5 / 68 mm (20G)
Turbine Wheel: 49.3 / 56 mm (TD05H)
TD06SL2/25G 4 IN COVER
Compressor wheel: 60.5/78 mm (25G Wheel)
Turbine wheel: 54.1/61 mm (TD06SL2 / 11 Blades)
Edited by stocker
Speaking of cams earlier I'm going a td06h 20g 10cm on my rb25 would poncams be worth it or would stock cams be my better option I was as much response as possible with as close to 300kw as possible even a tad more if I could
Im honestly not sure why your chassing the TD06H though, what we know suggests the L2 is going to be more responsive and able to max out the flow of the 20g with ease.
Dont forget Simon's T67 uses the same rear wheel as an L2, no flow issues with the 10cm....
A fair while ago there was a topic by STATUS with a poopra that ran twin TD06SL2's and I think made a tad over 1000hp
Do it, it will be a monster :)
Run dual 6cm L2 for around 800hp or dual 8cm for 800-1100hp on 98.
Ive tuned a few pairs on similar setups to yours i prefer the 6cm as it makes it very liveable down low, the 8s are ballistic.. forget 10cms.
thanks for the reponse and support guys..............lots of the poopra guys dont use these kinugawa turbo's think they are crappy ebayu jobs but are quiailty items...........where would i get a 6cm housing from that guy eiji from kando only dose a 8cm thats the smallest in their range for the td06sl2
would you have a link to the twin sl2 supra thread
has anyone used the kando/kinugawa td06h or td06sh its bigger then the sl2.........sl2 is only slightly bigger then a td05 ........i'll be using the 25g compressor wheel with 4 inche so what 2 will net me the 1000hp
here are the specs
here is the td06h
Turbine wheel: 58.8/67.2 mm (TD06H / 11 Blades Inconel Wheel (TD06H4)
here is the td06sl2
here is the specs for the td05
Turbine wheel: 55.8 / 49.1 mm (TD05H Inconel Wheel)
discount the above td05 turbo's as i ruled it out already
Edited by stocker
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
