you mean 250rwkw @ approx 13psi while the turbo is still half asleep, should see at least 300rwkw on 20+psi - I hope..
Great result so far, looking very interesting. My SS1 made 244rwkw on 98 fuel and 279rwkw on Caltex Eflex so everyone can get a rough idea that it would be around 250rwkw on 98 fuel in its current setup. Keen to see what it does with everything sorted!
DVS JEZ how is the ebay manifold holding up? and what turbo is it running?
Im keen to get one of these turbo's but don't want to spend the money on a 6Boost manifold for a budget turbo...
$250 mani +750 turbo + 400 gate + 600 for intake and dump ect = $2K for 300kw, seems awesome to me.
+500 for coilpacks
+700 for injectors
+500 for FMIC
+2000 for ecu and tune
+1000 for a clutch
+1000 for micselaneous bitsand pieces and fixing other little problems that may arise..
And lets hope your not paying for any labour...
2k for 300kw...yeah right...lol
are you still having troubles with the turbotech jez as i have one sitting in my shed and im on a bit of a tight budget also. and dont really want to fork out for a ebc if a turbotech is going to do the job
Someone on here made 330-340rwkw with a t67-25g (on 98) im pretty sure. So the td06sl2-20g should crack 300 with enough boost, And with much better response.
Will echo some earlier comments on this thread. I am very keen to see any engine that produces over 300rwkws on PULP98. Be it an SR20, EVO or RB25/26 or RB25/30. I think you will find that they often make 270-280. Occassionally 280-290rwkws....but I have never seen 300rwkws out of one .
So not sure why people say "should" regardign 20G compressors cracking 300.
Anyway, if current discussions pan out than I am going to billet compressor wheel on my 20G. So will be interesting to see if it loses power, makes power, loses response/makes response
Would you also be able to plot the boost curve? I am curious to see the difference between a 20 and 25. Especially since your VCT is off. Just means the extra compression and 500cc is working for you :cheers:
I think I'm expecting more also. There are plenty of results on Evo's to compare outright power against, I dont think outright power changes that much across engine types provided the motor can flow.
+500 for coilpacks
+700 for injectors
+500 for FMIC
+1000 for a clutch
Was talking about turbo upgrade and not the other stuff. Hypergear turbo's can get 300kw for $1550 but that's internal gate on standard manifold and you still need to make a intake. GT3076 again is either internal and might not make the power for more money.
my mates GTR made 337kw in rear wheel drive mode on 98.
luv psi the controller should be fine i think its more of a gate issue. i think it made my turbo laggy because i only had the 7 pound spring so the controller was holding back 11 psi its to much. try and get your gate as close as possible to boost pressure then use the controller to fine tune. how did you go with the manifold
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
