luv psi the controller should be fine i think its more of a gate issue. i think it made my turbo laggy because i only had the 7 pound spring so the controller was holding back 11 psi its to much. try and get your gate as close as possible to boost pressure then use the controller to fine tune. how did you go with the manifold
Thanks BSA I just rather not fork out for a ebc I have not got the manifold done yet as still getting car rego with rb25 first. What's your thoughts on getting the manifold ceramic coated
So your mates GTR ran a single TD06-20G turbo? So many people confuse the TD06-25G with the TD06-20G. The TD06-25G is bigger then the T67-25G
sorry, thought you were talking about in general silly me as this was all td06 talk lol
Trent posted a SR dyno that ran this on 98, 300.2rwkw
where on central coast are you located BSA?
also the one with the ext gate mod already, how much you want for that and will it suit 40-44mm v band wastegate?
+1 HPC is a waste of money for a street car. use heatshieldig or heat wrap.
luvpsi, either way works fine, but welding onto ex housing is an easier job.
Was talking about turbo upgrade and not the other stuff. Hypergear turbo's can get 300kw for $1550 but that's internal gate on standard manifold and you still need to make a intake. GT3076 again is either internal and might not make the power for more money.
i know of at least one guy making 350kw+ with IG HG on stock manifold :thumbsup:
LOL I think there are heaps of cars out with over 300kw on 98, Trent has even posted to expect 330-340 from a T67 on 98.
Certainly not the limit.
Sorry, reading back over my post. I was referring to all the people saying you "should" be able to get 300rwkws out of a 20G...Imy point was irrespective of motor, I am yet to see a credible/genuine dyno sheet of a 20G making 300rwks on PULP98. So if this thng gets up there then its a great result for the lil Kando, as the Trust and other knock off units traditionally have not been able to bag 300kws at the wheels. Be it because they are soft or just not enough people with the right setups using them??
People said that but the dyno sheet posted said 305hp on the axis. You might be right. It could have been 305rwkws with the wrong axis being shown. But seems high since most TD06 setups I have seen out of Dr Dift have been 250-265rwkws. Have you got the graph that you are referring to?
It was his personal 4 door 32 he had, he got a copy td06-20g (this was about 1.5-2 years ago) to 260rwkw on it and then added a front facing plenum and showed me the dyno sheet of it making 300rwkw, I went in the car when it was at 260 and it felt bloody quick because of the light switch on/off feel.
I was nearly going to get one of those turbos off him back in the day.
trent already confirmed numerous SR & RBs that made 300 on pump fuel, Roy.
I have seen similar posts and people reference it. I have never seen a dyno sheet. I have seen some T67 sheets. Not 20G = 300rwkws posts. I want it to be right, just want to be sure its right
Just not sure if its reliable info. Dont get me wrong, I want it to be. If there is another 30rwks in my setup I would like to know
These are the two dyno sheets I know of...
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=187000
And
http://www.nissansilvia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=184121
It says 305hp on the axis. If 305rwkws why does the axis say hp, surely it would read hp...but i dont know how the dynos work. If it is 305rwkws seems odd he is making 50rwkws more with 2psi boost. (18psi vs 16psi in the top end) Was also on the std RB25 injectors with increase rail pressure so ?!?!?! I am no expert but is it really reliable evidence? 124mph is impressive though I dont know the state of the tune at that stage?! What hp does that mph suggest?
ok Roy, im bored so i have collected some of the 300rwkw on 98 sheets just to satisfy you and shut you up.
a 10cm should get you there, with the right choice in cooler and hi flow cat and exhausts, there will be no restrictions provided the tune is spot on.
this was confirmed by Yavuz @ unigroup engineering who is highly regarded on this forum by sau:nsw members, he tuned many gtsts that made anywhere from 250-310rwkw, deciding factors were listed above.
1)
R33 GTS-T
TD06-20G turbo on high mount manifold
Tomei cams and cam gears
Forged pistons
650cc Injectors
Blitz external wastegate and screamer pipe
Blitz fmic.
Splitfire coils
Haltech E11v2.
On pump fuel
2)
SR20DET @ 19psi on BP98
Thanks Dori...lol I am going to back off because you seem to be cracking the sads with me wanting to be sure wires are not being crossed :)
My last post on it...I have seen that first curve before and I thought it ws a TD06-25G?!?! I suspect its a 25G just looking at it. It is making less power at 4,500rpm then my RB20 with a 20G
The second graph says GT-RS so ?!?!? Sure you are right but its hard for me to spot if I dont know the cars or the whole threads re the setup
There is also another graph floating around on an RB25 from a few years ago showing different levels of boost and that was a TD06 with Garret wheels so ? It made 330+ but it had 3037/3040/God knows Garret wheels.. Anyway. Carry on. :thumbsup:
And Yavuz/Unigroup...I went to Uni with him...no doubt he knows way more then me and I trust him. I will be seeing him in the next few weeks so will raid his files and bust his balls for graphs before i change anything on my setup
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
