External gate is VERY hard to keep hidden. Even custom jobs that I have seen where the intention was to hide the gate, it's still easily spotted if the cops are looking around. if you're worried about cops at all, I wouldn't be going external gate.
Here in the UK we don't have to worry about this defect crap. Anything goes so long as it passes an MOT test. I could have two 10 lbs NOS bottles visible, a massive bell mouth turbo, dump valves, side exit pipe, you name it. I don't even have to run a cat (but I do have an emission test to meet). It's bloody great.:thumbsup:
People car do things for all different costs, some cheaper some end up paying more.
I dare say since these setups work so well you would be best to spend the few extra dollars and making the setup 100%. Using some high temp sheathing on lines, good quality bends and reducers/flanges studs etc so you dont blow out gaskets etc or warp with temp.
A gate for $300? I paid about $500 for my Turbosmart. I paid more then $150 in just flanges, studs, gaskets and elbows + reducer. So not saying anyone was wrong but we all often pay different prices for things and I know i couldnt do my setup with external gate that cheaply
Is that the 8cm or 10cm turbine housing mate? I like the downpipe BTW and that is the trust triangle flange? Some peeps think it's ghey but not me.:D Also I notice your turbo is mounted very close to the front of the engine compared to Greddy copy mainfolds???
Edited by Tony de Wonderful
god some of you guys complain about some stupid shit. This turbo requires a ex WG so stop complaining that the cops will see it and rape your ass... If you don't like it sell your car and buy a excel or dont Modify your car.
So far im thinking i will go a T67-25G similar to SimonR32 setup and run eflex.
This is the 10cm housing with the original Trust manifold I was running at the time. Yeh all Trust kit with off triangular flanges, uses to run the total Greddy kit, these days its a bastard kit with Turbosmart gate and 6boost manifold
You are right, now that i am running a 6boost manifold the turbo sits a lot further forward and required moving the PS reservoir. Does give you a little more room for the dump pipe.
For what its worth, the 6Boost manifold resulted in a loss of a smidgen of power and hurt response a little. This could be the result of there being about 18 months between dyno runs and the car had lost a bit of performance in that time. I also changed from the Greddy Type R wastegate to a Turbosmart gate.
Cant see either really contributing to a loss in performance.
Considering the new setup has nicer piping and improved exhaust system...i think its safe to say 6Boost is no better then a Greddy manifold. Possibly worse. If all the handfeeding over 6boost manifolds were true I should have picked up some response and perhaps made a tad of power, especially given the exhaust improvements.
If I was starting from a clean sheet of paper I would go a Greddy manifold over 6boost now having tried both.
Is the 6boost equal length headers also? To be honest I doubt there is much room for improvement over design for exhaust manifolds from 10 odd years ago, just maybe 6boost are strong and don't crack etc? It's just lengths of pipe at the end of the day, choose your diameter and length (equal or not too) and away you go.
Yeh the Greddy manifold is a 6 into 2, 2 into 1 type manifold with a nice collector. The 6boost manifold is pretty much equal length into a slightly longer collector.
This is the greddy manifold...
No need to see pics of the 6boost manifold, there are plenty around the net.
The 6boost manifold many prove more durable, time will tell. But the above manifold is now being used on another setup by Kris with the L2 I pictured a few pages earlier. It did need a light repair on two occasions but nothing even my humble welding skills couldnt fix.
Nothing wrong at all with the 6boost manifold. They appear to be well built and plenty of people ave got years of great service out of them. I suppose the point is if you have a china manifold that is serving you well, a HKS or Trust manifold working well...then I am not sure there is any point wearing the 2K cost of replacing it with a 6boost manifold as I doubt you will get any performance increase
The one I saw was very average the collector is a nightmare and the flange was seriously warped..
post-22242-0-56924200-1324452119_thumb.jpg vs my 6 boost post-22242-0-92237800-1324452129_thumb.jpg
Is that one of the steampipe ones from nz mate?
im not fussed on chinese made etc, im running a chinese $70 one atm, but its bent and blows gaskets out on regular basis.. my chinese hi mount makes 470hp at wheels on 26psi thru gt35r on stock rb25 so i cant complain about flow 2 much.
yeh its the steampipe one from NZ around the $300 range... im all for using bang for the buck parts but that manifold was rubbish and I hate doing things twice so in the end the only solution was to pickup a used 6boost...
The thing that worries me with gate on manifold is police/ pits if you get a sticker and need to go over pits to go back to standard turbo you need another manifold if it on housing pull off turbo bolt on stock turbo get a basic tune take over pits done easy as
ya thats it, I just kept my bits so if i do get the defect, (which is unlikely cause i never drive the bloody thing :/) i can have it back to stock in a weekend..
Also
thats it finished
i think mines a little more inconspicuous :P
I admit its not hidden, but it does blend in well..Only someone clued on would spot it..
And if that someone looked under the bonnet well Im probably screwed either way...
Not sure if i will make a bracket to fit the standard heatshield or fab up a new one out of that heatshield stuff..
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
