Sure can buddy. Im hoping to be back on the dyno early next year. About to order a new 38mm tial gate with 14psi spring. Then i will use a bleed valve from there to up the boost.
Nismo Plate kit for my GTR diff is needed and only $300 i think its a better/cheaper option than a 2way
Remember that Jez's kit up is based around being budget orrientated, so Im sure theres a monetary decision involved in getting the 38 over the 44.
Jez I think you should get the 44 mate, do it once do it right.
Honestly i am just lazy in the way i dont want to pull the manifold off to cut the flange off. Unless someone has a 44mm 2 bolt wastegate. Plus i love the sound of smaller gates. Alot crisper note
Whats the next good value wastegate brand apart fro tial? I know u dont wana skimp on a critical component like this, just want to know what is cheaper and something thats proven like tial?
I got my Turosmart Compgate-40 for $330 which is fairly cheap. It wasn't so much about money for me as performance and compactness.
38mm gate doesnt sound big enough? But then I dunno much about ext gate setups except that most r using 44mm so kinda surprised, as even trent said that 40mm is the min he will go
Explain how u think the sound of the gate isnt big enough Ron
