Whats the difference between the TD05 and TD06? I wouldnt think there is enough wheel difference to make a difference. Is it because the TD05-18G you used was the T518Z rip off so has a different design housing?
Well I just ordered my TD05H-18G. Be interesting to see if backed to back with the TD06-20G. I am hoping I still make 250rwkws and hopefully make at least 25rwkws more at 4,500rpm.
Theres 4mm of difference between the two, and the housing in question is a TD05H specific item.. I dont believe in ground out housings unless they are proven to work. In this case Ive not heard of one of the TD06 IW housings working, yet have heard of one struggling to exceed 240kw (kando).
As for your setup, you will do it on a 10cm.. I think if I was doing a 20 I would run a TD06SL2-18g triangle 8cm. Ive read a few times over the years that a round turbine entry/flow path can give 30% more flow.. Just because its round. I think the 18g has a nicer ramp onto boost and would be good for keeping it on the boil around a track or even on the street.
Keen to see your results either way! And PM me if you have accumulated any SR spec trust housings along the way, I would be interested in buying one of these from you.
Isn't that a fairly small setup? Found a Kinugawa chart indicating they are good for ~250 crank kW at max.
Yeh with a puny 8cm housing on my 18G it is smaller then my Greddy TD06 setup that I am retiring...but am curious to see if it makes more power then an RB20 2530 setup...but with the same if not better response then a 2530 setup.
My TD06 is going off to get some fancy dildo spec alloy compressor so whilst its off being rebuilt will throw the 18G on and compare all 3 setups back to back over about a 2 week period. Greddy TD06-20G:8cm vs TD05H-18G:8cm vs TD06-73HTA. The claim is the new compressor on the 20G will give me T67 power with 20G response. Will see.
If that claim proves wrong and with the new compressor comes extra lag then it may be interesting to throw in the T67-25G I have. Problem is trying to convince the tuner this will be interesting to him to see the merits of each turbo setup...otherwise I will be sinking 2k into tuning just out of curiousity :(
In the back of my head I am curious to see what results the billet compressor gets as there are places in the US doign 68mm billet compressors for TD05H. That could work out to be a nice RB20setup, better response of TD05 but with 20G power
Gtscot, what made u downgrade from the mighty 1JZ to the tractor SR?? Lack of aftermarket support?
There was a 10k to do list on my JZR33 and a car I had owned previously came up for less than half that. Full prepped S14, only catch was the SR was rather tired and the wiring had been butchered since I last touched it.
Mrs bought me a spare motor with 55ks as a gift and I spent a few weeks rewiring the car. JZR33 partout price has exceeded S14 cost so far.
Simple stuff I guess, nothing like a tractor to pull you round a bend.
to whoever has removed the front housing off their turbo, how did you do it and was it hard to do?
noticed some metal shavings in mine after a closer look and would like to clean it up before installation!
has anyone been in contact with eiji lately?
i emailed him on monday cause i was missing the oil return from my kit and he hasn't responded.
Circlip pliers. pretty easy if you have the right tool and know what your doing...
EDIT: the return provided in the t67 kit is just a rubber hose... I went and got a braided line made up for mine.
Edited by battery
Was it a brand new turbo? If it was off a car then chances are they were from you removing it, otherwise they would have surely been ingested by now.
its brand new purchased from kando
they are a good product but you need to check that sort of thing before you put them on... only a mechanical part made on mechanical tools...
Circlip pliers and about 3 and a half seconds :)
hey i got a spare oil return if need
hey guys im jumping back on the wagon and going a kando again only on a sr this time (waiting for coment fron gtscott hahA) in thinking of running the tdo6 but the 18g does kando do the 06 in a t2 flange anyone know? dori i can give you a hand on sat as you will need to remove the front housing more then likly to fit it low mount i did anyway on the 32.
They do have a TD06 version of the one Jez was tuning the night I met you, but I doubt its what you want... I would stick to a TD05H if you want internal gate, or external gate TD06.
Internal TD05H-18g (trust T518Z):
http://www.ebay.com.au/itm/Turbocharger-SR20DET-SILVIA-S14-S15-TD05H-18G-Turbo-/270893185910?pt=AU_Car_Parts_Accessories&hash=item3f127dfb76
Internal TD06SL2-20g with T518Z housing:
http://www.ebay.com.au/itm/Turbocharger-SR20DET-SILVIA-S14-S15-TD06SL2-20G-Turbo-/270893186106?pt=AU_Car_Parts_Accessories&hash=item3f127dfc3a
Internal 20g like above but with 3" comp cover (i think this one would be better):
http://www.ebay.com.au/itm/Turbocharger-Kinugawa-TD06SL2-20G-w-T518Z-T25-Housing-/280806645825?pt=AU_Car_Parts_Accessories&hash=item4161616041
External TD06SL2-20g:
http://www.ebay.com.au/itm/Turbocharger-Kinugawa-Mitsubishi-TD06SL2-20G-T25-Flange-/280806646097?pt=AU_Car_Parts_Accessories&hash=item4161616151
And something I thought was very interesting:
www.ebay.com.au/itm/Kinugawa-Turbocharger-3-Anti-Surge-TD05H-18G-w-T3-8cm-V-Band-External-Gate-Hsg-/270880573643?pt=AU_Car_Parts_Accessories&hash=item3f11bd88cb
Somebody must want that one for an RB20!
I have bought one to go on my car. Though I stayed away from the ported cover as I am going to need the 18G to make all the power and response it can on my old RB20. I am very curious to see how the TD05H-18G stacks up against my TD06-20G that I am ripping off
This is the exact one I bought
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=280803976009#ht_2159wt_1270
I seriously need to wake up to myself. I now have a 3 spare turbos, 2 spare brake kits and 5 race seats for two cars :(
    • Great work! Give it a clean up with some Emery paper, and I'd run a thread die over the threads too to clean them up. It will make reinstall much easier, and also life easier for the next time it needs to come out.
    • I'm not a fan of high humidity, it's one reason I don't mind being further inland out Ipswich, except the last 3 odd years, the drought broke, and it won't stop raining, which is making the humidity nearly unbearable when the rains are in during summer! For me, my body hates the cold, once the cold sets into my body, I'm totally screwed. I end up with severe muscle spasm in my back/shoulder muscles, and it feels like someone is trying to tear the muscles out. I have no issues with it getting stupid hot, so long as the humidity goes away. So the last 3 years as above, have been woeful! Ha ha. However, June 1st, and I'm only just converting from shorts and a tee, to long pants and a t shirt. And that's mainly as it's a bit wet and miserable and I wanted to work on a car.
    • I much prefer colder weather to hot weather, and especially prefer cold to hot and humid, Goulburn does gets pretty warm in the hotter months, but, I've found the humidity there is not as painful as even Sydney, the humidity up north is to oppressing for this old rooster  In saying this, it does get rather "nippy" in Goulburn for early morning, late in the evening walks, but nothing that a layer or two, some thermal gloves, and a beanie doesn't fix to make it an enjoyable experience, which is much more bearable to me than the oppression of heat and humidity,  especially at night when your trying to sleep If I recall correctly, a "wise man" once said that the "Southern Tablelands" was gods country, and I will not argue that point with him for the fear of a "permaban" LOL In car part related news: My intake is currently in Botany getting processed for the last leg of its shipping journey to my door
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
