hey guys...my mate just showed me this site that i really liked and thought to share it with you guys....
half of you guys prob know about it....
http://www.drivingfast.net/
now all is left if to practise the theory in real life :P
https://www.sau.com.au/forums/topic/347805-driving-techniques/
That's brilliant, thanks for sharing!
Reminds me of some very basic motorkhana stuff I tried a couple of years ago. Heaps of guys in their modded big power cars, all beaten with ease by this one dude in a bog stock s___box V6 commodore - he just knew how to drive.
"It's not the equipment, it's how you use it"
very very true...thats why i really enjoy reading this kind of things even though they seem logical but when you use them properly on the track, you get great results...and the best thing i liked about this is that its advice not only for tracking but also had heaps of info for normal day to day driving...and how you can just in general drive smoothly and safely...
Not bad, the one that always gets me is the change from fourth to a 3rd gear corner i always try to change as late as possible but often to late and the rear end tries to step out, can be a little scary..
I can only imagine doing the same from fifth to fourth cause i always makes sure i change early for these but i get a bit over confident for the 3rd gear corners that have nearly caught me out a few times..
Of course none of these techniques really prepare you for an unexpected dip in the road when on the street that can send your car sideways in a split second if hit at speed..
Ive travelled many a road after hearing about fatal accidents only to find there was a big dip that you know has been hit way to fast and launched the vehicle sideways into a pole or similar. Match this with rock hard lowered suspension or with crappy king springs shit shocks and low profile tyres and its a recipe for disaster..
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
