Hi All,
I am chasing an un-modified R32 GTR, preferably 92 to 93 model.
With honest looking kms, no BS, price is not an issue at this stage as I want to find the perfect car.
My immediate choice would be White or Silver, aftermarket wheels are ok if they are not ridiculous
I am looking at buying very soon, so by all means let me know if anyone has what I am looking for.
Cheers,
Ben
https://www.sau.com.au/forums/topic/347834-wtb-r32-gtr/
  • 3 weeks later...
ive got nismo GTR fairly stock im looking to sell.
white, 1990, 71000klms.
heres the link to the Ebay add. NISMO GTR
im from the NSW central coast.
let me know if your keen or give me your price if your not.
https://www.sau.com.au/forums/topic/347834-wtb-r32-gtr/#findComment-5609397
  • 3 months later...
Thanks for all responses guys.
Looking to spend no more than 25, unless its something really special! Well Id love an Aus delivered one, but 50k more is not really and option
I am still looking,
Preferences:
Gun Grey
BB Turbos of some kind
No rust
Air con Working
Not fussed if hicas is removed or not
Please no 15k rusty gtr's or gtr;s in need of a motor or pistons etc.
Looking for 18k + nice examples
Cheers.
Ben
https://www.sau.com.au/forums/topic/347834-wtb-r32-gtr/#findComment-5790892
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
