HEY WRECKING A R34 25GTt
ITS WHITE, WITH DAMAGE TO THE PASSANGER SIDE AND LIGHT FRONT.
STILL HAS REGO NOT WRITTEN OFF.:whistling:
I'LL LIST PARTS AND PRICES BUT IM NEGOTIABLE, MAY HAVE MORE PARTS NOT LISTED SO ASK.
>LEFT HAND SIDE REAR TAIL LIGHT $70
>REAR BAR SCRATCHES NEEDS PAINT $50
>BOOT CARPET 7 PIECES $100
>REAR WINDOW (REMOVED) $150
>BOOT SEAL $10
>BOOT STRUTS $10
>FRONT AND REAR SEATS $200 (BLACK AND GREY)
>PARCAL SHELF $25
>REAR ("DOOR TRIMS") $25 EACH SIDE
>REAR PILLAR PLASTICS $25 EACH SIDE
>DRIVERSIDE DOOR COMPLETE $250
>DRIVERSIDE MIRROR $50
>AIR BAR STEERING WHEEL $150
>IGNITION BARRAL/DOOR/BOOT LOCKS AND A KEY $100
>IGNITION BARRAL COVERS $50
>DASH CLUSTER $100 85,000 K'S
>INDERCATOR STALK $25
>WIPER STALK $25
>REAR SEAT BELTS $50
>HKS HYPER D FRONT COILOVERS $450
>STOCK STRUT BRACES FRONT $25
>REAR STRUT BRACES (STOCK) $25
>DIFF $250
>EXHAUST, DUMP PIPE, HIGH FLOW CAT BOUT 3INCH $200
>STOCK REAR STRUTS $100
>REAR CRADLE $100
>BRAKES COMPLETE
.YOU GET ANYTHING YOU NEED HAND BRAKE ECT
$800
>COMPLETE MOTOR PACKAGE
.AFM
.LOOM
.ECU
.INJECTORS
.COILS
.ANYTHING YOU NEED
$2500 85,000 K'S
MANUAL CONVERSION
.GEARBOX
.SHIFTER
.TAILSHARFT
.CLUTCH MASTER
.PEDALS
.ANYTHING ELSE YOU MAY NEED
$1800
ALSO I HAVE SUSPENSION PARTS THAT I HAVENT LISTED HAVE TO CHECK CONDITION
I WOULD LIKE TO KEEP THE MOTOR RUNNING UNTIL I SELL IT BUT WOULD ALSO LIKE TO MOVE ON THE BODY.
I HAVE LISTED PRICES BUT I AM NEGOTIABLE. I JUST SET A FIGURE TO WORK AROUND.
CAR IS IN MANSFIELD PARK 5012
THERE IS NO FRONT PARTS EG... LIGHTS BONNET GUARDS ECT.
WILL POST MOST PARTS BUT YOU HAVE TO PAY POSTAGE.
MAY TAKE WORK WHEELS AS PART TRADES
XT7 OR XD9'S IN 5 STUD :banana:
Edited by skyline_r33_panda
https://www.sau.com.au/forums/topic/347853-wrecking-r34/
SORRY IF I HAVENT REPLYED I HAVE HEAPS OF PM'S
TRYING TO BE FAIR WITH SELLING PARTS BUT
FIST IN WITH THE CASH GETS THE PARTS
I NEED TO KEEP THE CAR COMPLETE MOTOR WISE BECAUSE I HAVE SOMEONE INTERSTED IN LOOKING AT IT RUNNING
https://www.sau.com.au/forums/topic/347853-wrecking-r34/#findComment-5596285
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
