HEY WRECKING A R34 25GTt
ITS WHITE, WITH DAMAGE TO THE PASSANGER SIDE AND LIGHT FRONT.
STILL HAS REGO NOT WRITTEN OFF.:whistling:
I'LL LIST PARTS AND PRICES BUT IM NEGOTIABLE, MAY HAVE MORE PARTS NOT LISTED SO ASK.
>LEFT HAND SIDE REAR TAIL LIGHT $70
>REAR BAR SCRATCHES NEEDS PAINT $50
>BOOT CARPET 7 PIECES $100
>REAR WINDOW (REMOVED) $150
>BOOT SEAL $10
>BOOT STRUTS $10
>FRONT AND REAR SEATS $200 (BLACK AND GREY)
>PARCAL SHELF $25
>REAR ("DOOR TRIMS") $25 EACH SIDE
>REAR PILLAR PLASTICS $25 EACH SIDE
>DRIVERSIDE DOOR COMPLETE $250
>DRIVERSIDE MIRROR $50
>AIR BAR STEERING WHEEL $150
>IGNITION BARRAL/DOOR/BOOT LOCKS AND A KEY $100
>IGNITION BARRAL COVERS $50
>DASH CLUSTER $100 85,000 K'S
>INDERCATOR STALK $25
>WIPER STALK $25
>REAR SEAT BELTS $50
>HKS HYPER D FRONT COILOVERS $450
>STOCK STRUT BRACES FRONT $25
>REAR STRUT BRACES (STOCK) $25
>DIFF $250
>EXHAUST, DUMP PIPE, HIGH FLOW CAT BOUT 3INCH $200
>STOCK REAR STRUTS $100
>REAR CRADLE $100
>BRAKES COMPLETE
.YOU GET ANYTHING YOU NEED HAND BRAKE ECT
$800
>COMPLETE MOTOR PACKAGE
.AFM
.LOOM
.ECU
.INJECTORS
.COILS
.ANYTHING YOU NEED
$2500 85,000 K'S
MANUAL CONVERSION
.GEARBOX
.SHIFTER
.TAILSHARFT
.CLUTCH MASTER
.PEDALS
.ANYTHING ELSE YOU MAY NEED
$1800
ALSO I HAVE SUSPENSION PARTS THAT I HAVENT LISTED HAVE TO CHECK CONDITION
I WOULD LIKE TO KEEP THE MOTOR RUNNING UNTIL I SELL IT BUT WOULD ALSO LIKE TO MOVE ON THE BODY.
I HAVE LISTED PRICES BUT I AM NEGOTIABLE. I JUST SET A FIGURE TO WORK AROUND.
CAR IS IN MANSFIELD PARK 5012
THERE IS NO FRONT PARTS EG... LIGHTS BONNET GUARDS ECT.
WILL POST MOST PARTS BUT YOU HAVE TO PAY POSTAGE.
MAY TAKE WORK WHEELS AS PART TRADES
XT7 OR XD9'S IN 5 STUD :banana:
Edited by skyline_r33_panda
https://www.sau.com.au/forums/topic/347853-wrecking-r34/
SORRY IF I HAVENT REPLYED I HAVE HEAPS OF PM'S
TRYING TO BE FAIR WITH SELLING PARTS BUT
FIST IN WITH THE CASH GETS THE PARTS
I NEED TO KEEP THE CAR COMPLETE MOTOR WISE BECAUSE I HAVE SOMEONE INTERSTED IN LOOKING AT IT RUNNING
https://www.sau.com.au/forums/topic/347853-wrecking-r34/#findComment-5596285
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
