Help ` Ive Been Ripped
I never got his name - I just checked his mobile number against the scammers list.
Hey
I'm sorry I can't help out with any other scams, but if you feel as though you have been scammed by "HO YOUNG" - see Ash's post in this link for relevant details
http://www.fordxr5turbo.com/forum/index.php?topic=10253.msg293968#msg293968
If any of the info match this description, there is already a case filed against this man. The police force has told me that this particular person has already done jail time in the past, and is now repeating as he sees this is an easy way to make cash. The best way at the current time to show this guy a lesson is to file a legal statement to the police. If you would like the details of the particular officer, please PM me. She is taking the case very seriously and wishes to bring us back justice. All that is involved is you will be asked to submit your story and sign it. These files will be filed towards the QLD police who will ask him to stand in court. If that fails, it becomes a civil matter. At this point (as I already said in my other post), I will be happy to bring my lawyers in and absolutely rape this guy - force him to sell this damn children to reimburse all that have been cheated.
But your part will be to file those reports :)
Hey
http://www.fordxr5tu...93968#msg293968
I lost half my lunch all over my desk thanks to that line. Well played.
glad it all worked out for u in the end mate. But I do hear your pain about being scammed/duped into handing over money and never receiving the goods.
What I would like to propose to the moderators (from experience on the g35driver.com forums) is that on each ad placed in the "for sale" forum that it is mandatory to place a picture of the item with a placard displaying the forum members user-id and current date. Doesn't have to be anything fancy, but something in whiteboard marker on an A4 placed next to the item and a photo taken so it clearly shows both the item and seller details.
That way ppl can't grab pictures over the internet and claim to possess the items for sale. Sure they will be ppl saying well you can photoshop the details on the photo...but its more a deterent to scammers
  • 3 months later...
Well looks like i totally missed this thread, serves me right for going interstate for a week.
Was wondering how on earth this thread got to 3 pages in the last 24hrs without me noticing.
I echo Blitz statement earlier.
I've spent at LEAST 30hrs in the last 6 months helping users who have been scammed. SAU doesn't have to help - but we try our best within the laws of this country.
Have some respect but more importantly - ensure you engage the brain before you hit "send" on the EFT. We can't save you from yourself.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
