Hey there so as title says im having trouble working out whats wrong.. with what part haha
firstly when i had my car rwc'd a few months ago mechanic told me that engine mount had a crack and should be replaced.. (have not done it yet as its looking like an all-dayer, and had a look through the FYI section and only found one for replacing on a silvia... which is a hell of a lot easier)
so does anyone have any tips on this one?
now box/clutch,
when changing down thru gears its hard to get it into the gear.. mainly in 4,3,2 but if im not applying the brakes it is easier... :S very confusion..
when taking off in first, and then stoping again in first (eg at a busy traffic lights) i cannot get it out of first with the brake on (i have to slow down, realease brake, then go back to neutral... cannot just stop with clutch in and in first.. its astho the clutch just doesnt release)
and when it does release it makes a big clu-dunk sometimes and still needs a good yank to get it out
my clutch is a twin plate brass button, and it doesnt feel like it is anymore... (when taking off in first i can ride it a fair bit.. it used to just be on/off..
also i have checked clutch lines, i havnt lost any fluid, and there isnt any evidence of fluid along the lines from mast down to slave..
so first question could the engine mount be causing me troubles if its cracked all the way thru,, ie made everything out not line up right?
could my clutch just be worn and need replacing?
do i have a problem with my box?
does it sound like clutch bracket? have read something about it but no idea whr it is /what it looks like :S
anyone else had this problem?
thanks i really need to get ontop of this and my pet hate is getting a mechanic to do it.. hahaha
all feedback apreciated
thanks Simon G :)
Sounds like it could be a clutch fork problem, it might have bent a little causing the clutch to not fully disengage when it's all the way to the floor making it hard to shift gears and crunch when you try to engage them at a stand still.
The easiest way to check it is to pull your slave cylinder off, pull the push rod out of it and get one made up that is slightly shorter by about 3-4mm or so and re-install it. If your clutch feels normal again after doing that your clutch fork is bent and you need to replace it.
Edited by Dobz
update the problem has been getting worse over the last month or 2.... and today ive been barely able to get into 1st... had to do some 2nd gear starts...
and also the clutch has lost alot of pressure,. ie. i dont hav to use as much force on it..
btw thanks for the input Dobz... but just before i go and dismember my salve cyl id like to hear other peoples idea's and or agreeance.. :)
it does feel astho if i could push the clutch through the firewall it would let me move gears easier tho.. is there a way to adjust how much the pedal moves/pivots? to give me that extra leeway..
also havnt bled the lines yet.. didnt think it would be neccesary as i see no evidence of leaks and how would air get in there otherwise? :S am i wrong :| :S
also read that twin plate brass buttons wear quite quickly too.. when i got the car it took me a long time to learn how to drive again -__- could it just be effed?
A worn clutch won't make it harder to shift gears it'll just slip and make your revs flare out. There is an adjustment on the clutch pedal, you could get under there and wind it out further so the master cylinder gets a bit more push. It would be a good idea to bleed the system even though you see no leaks just to rule it out, that is if adjusting the clutch pedal doesn't do much.
thanks guys :D im gna hav a crack at it tommorow after work :) also i jus realised tonite its not to bad at all when its cold.. as temp gauge goes up it gets worse amd worse.. makes me think cylinder seals?
just spent a good 45 mins bleeding cyls and lines wondering why it wasnt working only to look under the dash to see how mcfckd the bracket/s? were it looks like there is 2 of them? one has completely riped the middle out and the other is cracked and hanging.. both are about 5+ cm away frm where they shuld b haha .. been revmatching allday -__- great.. haha il post some pics soon and a vid  thanks for help guys!
cheers!
simon g
    • As strange as this sounds (as they are fixed back), my Bride Xero CS seats are the most comfortable seats I've used.  I vote go genuine.  The only downside I've found is on very long drives, you can't reposition your body while driving. So even though its comfy, being locked in the same position eventually becomes uncomfortable. I find myself stopping every 3 or so hours to stretch my legs on long drives.
    • You don't have to be bored driving a Camry. Not based on the way that a couple of f**king Ubereats/Didi/othersortofmethaddlednightshiftattheservicestationrecentimmmigrants were piloting them on the way to work this morning. f**k me dead!
    • FWIW, the Bride reps are really nice to sit in. The only complaint I have, other than the tear in my bolster, is that the velcro used to hold the backrest cushion in place, up under the headrest, is a little obvious and intrusive and could probably be done better. I don't know if that is a "feature" on the genuine ones also though. I haven't looked at a genuine one like the ones I have, only some of the older models. The other thing is, even though I bought the CF ones, I think the CF is really just decorative, over the top of the same FG as the normal seats. And so they really aren't light. Between the solidly built CF/FG seat, the steel frame in the recliner mechanism, and the solid-arse seat rail, they are probably heavier than even the stock seat. They are a serious lift to get in and out of the car.
    • Yes, and so the barest minimum power target is the one that makes the most sense. Massive power is fun, but you can only use it for 1.5s at a time, and only every now and then. Medium power levels allow you to enjoy the car far more often and for longer. 500 engine HP is just below 300 rwkW which is about the maximum that is sensible for any street car really. And for a 2.6L six, it will still leave you with a decent boost response and some sort of linearity of power delivery. As you get up towards 400rwkW the onset of power tends to be increasingly like a cliff and you need drag radials to keep the ground in proper contact with the car, and.... it's just not a car for driving around any more.
    • I already reached that conclusion myself after reading up a whole bunch and watching various videos from multiple sources. Don't know yet how I'd best manage that with the least amount of headache. Probably pulling the sump and just welding on a AN10 adapter or something. I also think it's healthy to take most opinions with a grain of salt, because experiences differ wildly and especially Aussies - when talking about RBs - don't know a world below 600whp drag builds. Personally I doubt I will ever take my R33 racing, so it's going to be a street car with the occasional spirited drive. Hence why I am (so far) under the impression that I'm going to be fine with a stock-ish engine for a while.
