Hey all,
I purchased my r32 only like a month or 2 ago.
The car feels very slow/sluggish until boost kicks in.
I get munched by little yaris/jazz/swifts etc... at the lights (just driving normally)
Boost on car does not kick in until atleast 4-4.5k!
Car has fair bit of work done to it.
CAI
Pod
FMIC
3" TBE
Pon cams
Cam gears
Bigger injectors
Better coilpacks
Z32 AFM
Upgraded fuel pump
Bigger turbo
Nistune ecu (can't remember if that's the correct name)
Few other bits.
I hardly ever floor/race my car as turbo lags and it drinks so much petrol... i'm a GRANNY driver! LOL.
However when i drive normally it's so slow/sluggish... all these cars just overtake me and the ones driving behind me get's frustrated that i'm so slow.
Car does not feel like a straight 6 down low in the rev unless turbo kicks in. Getting overtaken and beaten by 1.3L is a disgrace!
Is this normal or what's up with the car?
Any advice/help would be great.
Thanks guys.
Edited by starscream_r32
Sounds like you have a bad case of rb20, only way to fix it is with some extra capacity.
Also didnt you test drive this vehicle before driving it? Even if you were just riding passneger it should have been fairly obvious what sought of power you were getting.
Find out exactly the specs of the cams are, as they don't add power, but shift the power up higher in the revs which is why you are seeing no low to mid-end power, great for track driving... not so for daily driving. You could dial in the adj. gears to help bring the turbos on earlier but need a dyno to confirm the changes.
lol.. guys i'm talking about racing off the line!
i'm saying normal driving/take off it's slow/sluggish unless i put the foot down and get it into the turbo boost band.
should still have some umphh even without the turbo kicking in? Its' an inline 6! feels slower then a 4cylinder. loll.
Turbo is hypergear 28?
Yes car is tuned.. (probs needs a retune) but it is tuned with current mods. about 235rwkw on dyno sheets.
its an RB20... has no VCT
There not that punchy off boost, but they do rev nice, most of the power is when the turbo comes in, and without the VCT you dont feel the torque like you do with a RB25
Please show a photo of this turbo or the person whom you've got it from, I will be able to give you some specifications of it if it is one of ours. Also check the wastegate actuator adjustment. Make sure its tightly shut.
A healthy RB20det should still be pretty ok down low even without VCT. I would check cam timing and have a play with cam gear settings.
u sure it doesnt have a dirty big set of 280 cam and some poorly matched or hybrid turbo?
cam and turbo selection can quiet easily make it feel like a bucket of shit down low
type in www.google.com and search RB20 lag...
Do some research on what parts you already have prior to running to a tuner. many will pick up you haven't got a clue and wrought you..
RB20's do not have low down torque. dont expect much until it comes on boost or at least is well above 3krpm.
RB20s are crap off boost. think of it like this, a 2 litre towing a 1300kg car, slow... 235rwkw from a 20 makes me think it would be really laggy which would then make the painful wait for boost even longer! i know mine is painful but my boost starts at just over 2000rpm (stock turbo lol)
having said that i don't know what difference cams and some of the other mods would make, mine only makes just over 160rwkw
haha what you expect? To drive around below 2000rpm? This aint a V8. The engine was designed to rev out. Hell, the redline is 7700rpm afterall. If you are after more response, sell off the turbo and replace with a HKS2530. Comes on boost at 3800rpm~ and will give you max power of 210kw~ Else, live with it and rev out to 4000-5000rpm between shifts.
My r32 has an average fuel economy of 11.5Ltrs/100km~ Work out if yours is similar.
if you take the car on the track, you wont be seeing under 4000rpm anyways, so decide what the plan with the car is and start to change whatever you dont like.
i rarely got past 3k.
so ur saying if i keep all gear changes under 3k without kicking the turbo in then from stat to finish ill always be slower/behind other cars?
even lilttle 1.3,1.5L etcc are faster/ahead of me?
dunnoo. if u guys get what i'm talking about but yer... maybe u needa be in the car to understand..
everyone that sits in my car thinks its slow cos i keep it under 3k and not let the turbo kick in... but boy do they get a surprise when i rev it though..
lollll..
i'll get a retune and fix a few little stuff and see how i go..
turbo cars are designed to go fast when boosted. Simple as that.
non turbo cars have the advantage of no lag, and I think your forgetting that some little cars, even with there small 1.4L engines etc, are still quite light and if there putting there foot flat to the floor, the engine will be at its peak performance, where as your RB20 at say 1/4 throttle, off boost will be no where near its potential.
your saying we arent getting it? is there a better way you can explain it if the above is not how your driving it?
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
