hi guys, just got my rb3026 run in and the proper tune done on it but we cant get it past 315kw atw, doesnt make any more power, can wind in more boost pressure but it doesnt make a difference. here is the mod list
rb3026
t04z .84 rear housing
50mm gate
hdi rs spec cooler (95mm thick one)
pon cams b spec 9.15mm lift 260 duration
cam gears
ported head standard size valves
3.5" turbo back and cat, 3" from cat back
splitfire coil packs
1000cc injectors
built engine etc
its like there is a restriction somewhere, pulled exaust off before cat, made no difference, took of turbo inlet pipe, made no difference, checked the cooler incase i left a rag in the but nope. as I said the boost pressure is there but its like the flow is not and the pressure holds steady till redline it doesnt taper off at all. this setup should be able to make 400kw so yeh if anyone has any ideas id love to hear them
car goes fkn hard but yeh id like the extra kilowasps that should be there lol
cheers
https://www.sau.com.au/forums/topic/347991-cant-get-more-than-315kw-atw/
  • Replies 58
messured? boost pressure or flow across the cooler? I looked the cooler up on hdi's website and they say its good for 900+ hp, Its new and there arent any leaks.
spent the better part of a day fiddling with the cam gears on the dyno, got good midrange but just cant get past 315.
I just remembered when putting the exaust manifold on it didnt line up perfectly with the exaust ports (used indian ink to check), its not a cheapy though, is a stainless one off the shelf from gcg. I dont know if that would cause this to happen though
I just remembered, I have a split pulse exaust housing and a non split pulse manifold. (I know got a bit excited when I started this build 2+years ago and went out and bought a manifold and stuff before id come to the point of needing it)
Edited by s13_Skyline_inside
i was about to suggest taking a look at exhaust manifold. by how much did the ports not perfectly line up?
are u checking boost close to manifold as u wind it up? as in is the engine actually seeing more boost? wastegate spring isnt at it thresh hold and bleeding off or anything is it?
cause there are plenty of 900hp cars in china to do r&d for them....
yer accross cooler core would be somewhere to start.
2-3 mm doesnt seem right on the exhaust manifold not lining up to me.
are u using map sensor or afm? at what psi does it stop making power?
The divided .82 turbine housing is WAY too small. it's equivalent to about 0.5-0.6 a/r in a regular housing. Definately not great having a regular manifold and divided turbine housing either.
Port match the exhaust manifold to the head and get a .82 regular turbine housing and it should be all sweet!
Edited by bradsm87
Frst thing i would be trying is dropping the exhaust at the cat the doing a power run. 3" cat back seems a little small for big power.
edit, should have read the whole post.... you already tried that :whistling:
0.8 divided rear housings on a T04Z have been shown to make between 430-470rwkw
I dont know why anyone has not realised yet, but I believe this is definitely the problem.
You have an open frame T4 manifold with a split pulse T4 turbine housing, the entry to the turbo has a serious restriction in it. As does the manifold if it doesnt like up perfect.
I think you should ditch whatever manifold that is and switch to a 6boob immediately, you have 400kw to crack.
yeh im leaning towards the mani being the issue, I do love the 6 boost ones, but I have a few things to check first before I fork out the dough, will keep the post updated if (should say when) i make any progress
its not the rear housing thats for sure.
A friend is making close to 450kw with the same t04z .82 turbo. To be on the safe side drop the exhaust while your at it and check the cooler. If power shoots up, rebolt the exhaust back on. If the problem reappears you know its the exhaust. If it dosnt, Most likely the cooler.
.82 split or single?
a.d the exhaust was ruled out in the first post.
Split pulse housing on single entry manifold as per post 3.
Considering the ports off the head arent perfect and we have well and truely established that the turbo flange is wrong, I am willing to put money on it that this is the issue.
I would go throw that chinese made POS back at GCG and get the real deal. If it was them who sold you the turbo with the manifold you should seriously flame them (though I would just cut my loses and move on).
Im not sure how many times I have harped on about this, yet on an basic SR, I saw a 76mm test pipe mated to a 80mm system stop the motor from making any more than some pathetic number.. Popped an 80mm cat on and hey presto pushing over 200rwkw instantly.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
