i have for sale r33 gts t series 1
recon alt $120
starter motor $80
series 1 boot wing $60
standard r33 gts t dump pipe $50
s2 turbo done very low kms comes with pipes etc $350
standard r33 air box with panel filter $90
some other bits and pieces that have to go!
https://www.sau.com.au/forums/topic/347994-r33-parts/
r33 parts price drops
recon alt $100
starter motor $70
series 1 boot wing $40
standard r33 gts t dump pipe $40
standard r33 air box with panel filter $80
0411373366
https://www.sau.com.au/forums/topic/347994-r33-parts/#findComment-5627268
  • 3 months later...
Is the air box still available, and how much for express post to Sydney?
recon alt $120
starter motor $80
https://www.sau.com.au/forums/topic/347994-r33-parts/#findComment-5814956
where did u get the alt reco'd? all the auto eleccys in nsw cant find parts anywhere!! all they can do is new bearings.
whats been done to your alt? receipts?
cheers
https://www.sau.com.au/forums/topic/347994-r33-parts/#findComment-5815002
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
