i have for sale r33 gts t series 1
recon alt $120
starter motor $80
series 1 boot wing $60
standard r33 gts t dump pipe $50
s2 turbo done very low kms comes with pipes etc $350
standard r33 air box with panel filter $90
some other bits and pieces that have to go!
https://www.sau.com.au/forums/topic/347994-r33-parts/
r33 parts price drops
recon alt $100
starter motor $70
series 1 boot wing $40
standard r33 gts t dump pipe $40
standard r33 air box with panel filter $80
0411373366
https://www.sau.com.au/forums/topic/347994-r33-parts/#findComment-5627268
  • 3 months later...
Is the air box still available, and how much for express post to Sydney?
recon alt $120
starter motor $80
https://www.sau.com.au/forums/topic/347994-r33-parts/#findComment-5814956
where did u get the alt reco'd? all the auto eleccys in nsw cant find parts anywhere!! all they can do is new bearings.
whats been done to your alt? receipts?
cheers
https://www.sau.com.au/forums/topic/347994-r33-parts/#findComment-5815002
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
