I have recently purchased a r32 skyline gts. i had been driving it around perfectly fine for a couple of days then out of no where, the power windows and all the gages and warning lights except for the speedo stopped working. the engine still runs fine and the car drives without problems. anyone know what may have cause this?
thanks for the help
https://www.sau.com.au/forums/topic/348008-electrical-problems/
The speedo will work because it's mechanical.
Do the warning lights come on when you put the key to "ON", ie just before you start the engine? Any other symptoms you can tell us about?
Maybe check the fuses with a multimeter - often the fuse can look perfectly ok but have the smallest of breaks in the fuse material.
The fuses have two metal points on each end. Earth a test light and test both points of the fuse make sure all the dash/accessories/power window fuses work.
If you've got an aftermarket stereo, there is a slim chance the wires could be melted or somethings gone wrong. Ive seen a ford laser have its wires melted together because the draw of the headunit was too much for the wiring in the car. Caused alot of electrical issues..
  • 3 months later...
Car batteries are much better today than they were even a few years ago. I've had batteries last as long as 9 years in a car, which is amazing. Only a few years back, the "60 month" DieHard car battery from Sears was considered the top of the line. Technology has improved over time.But car batteries can fail at any time, even when brand new. And although they can last as long as 9 years, typically most fail in the 5-7 year range, if not before. And cheaper batteries might not last even that long.The failure mode of car batteries appears sudden, which is something that confuses people. Most folks' experience with batteries is based on flashlight or other consumer product batteries. A flashlight battery fails slowly over time, getting dimmer and dimmer, until one day, it is a mere flicker and then goes out. Consumers think that this gradual failure mode applies to car batteries as well, which is why they dismiss the battery as the problem when the car "suddenly" fails to start. bmw tail lights
Edited by jazmin
  • 8 months later...
anyone have any ideas?
my car has just randomly done the same thing except in a 32 gtr.
no dash warning lights when you turn the key to on, the front torque gauge goes all the way up to max, no power windows etc and there is a relay in the boot that keeps ticking every 30 seconds?
start the car and using a multimeter check if the alternator is charging. i have come across a number of cars that cause failure to dash and power windows etc. when there is a fault with the alternator. it could be the alternator itself or even a broken wire going to the alternator.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
