Hey guys,
got another few problems with my car and need some advice.
1. Today while driving i can smell fuel inside my car.
It's not strong but there's a feint smell. It seems to come and go at times.
Anyone able to direct me to where or what it could be from?
I've tried lifting the bonnet and smelling the engine bay but there's no smell. Also tried going to the back of the car and can't smell anything either.
2. How do you tell if the fuel pump is dead or on it's way out?
When i turn the key to ignition on i can hear like a squeaky sound coming from the back for a couple of seconds (should be fuel pump making the noise) is it meant to make this sound?
Also when i start the car... i have to almost always give the car a bit of gas for it to start. Hardly every starts without touching the pedal and when it does it takes a few cranks or a continuous crank for it to start and then it kinda struggles to keep the car alive.
After that car is fine.
I assume the fuel pump is dying? If it is is anyone able to tell me what an equivalent fuel pump to a R34 fuel pump would be? (eg. walbro?) a r34 gtr pump is gonna cost like $500 or more.
Or can someone tello me how much a r34 gtr fuel pump puts out so i can find something similar? Don't wanna get something different/less cos it'll need a tune?
Thanks guys!
https://www.sau.com.au/forums/topic/348028-fuel-smell-in-car-fuel-pump-bad/
My r33 has this same problem, no one knows what it is
if the fuel pump was dying it should run poorly as well as not starting properly. the only way to tell for sure if the pump is failing or not is to put it on a dyno. this way you can see what the AFR's are like at high rpm. if they are fine then the pump is fine. if it starts leaning out at high rpm then the fuel pump isn't able to supply enough fuel and needs to be replace.
you should hear a noise when you first turn the key to ON, as that is the fuel pump priming. as for the noise it's making when you do that, it's hard to say whether it's something to be concerned out without hearing it.
the starting issue can be caused by lots of things. i'll list a few: weak coil packs, weak ignitor pack (on earlier models), wrong gap on spark plugs, dirty injectors, low compression, fouled cold start valve (that's a pain to clean, but might be worth checking out), faulty AFM, incorrectly adjusted TPS. that is all i can think of to right now.
thanks for the post.
yeah i know there's the prime sound but in addition to that there's this kinda squeaky sound like a mouse or something.. LOL.
guess i should take it for a dyno/tune then.
sometimes the squeak can simply be the pump vibrating on the bracket as it primes, which is nothing to worry about, however if the squeak is coming from inside the pump then it is a little bit more of a concern. only way to tell which it is is to pull it out (which is a bit of a pain). i'd say taking it to get some power runs on a dyno would be the easiest option.
  • 3 weeks later...
Check it fuel lines. Had same problem. Mine were one of mine was loose were the line leaves the fuel filter. The hose clamp was not fully tight and only sometimes it would leak fuel. Lol scary. And that's why I could only smell it occasionally.
  • 2 months later...
Also check the lines on your carbon canister. One of emits a small amount of fuel vapor which you do not want forming a cloud in your engine bay while engine is running. Mine used to pop off all the time pain in the ass.
I have a bad fuel smell only when the window or sunroof is open!!
Checked the charcoal canister and its hooked up correctly, no fuel leaks found in engine bay either.
Im guessing it could come from the rear boot?? someone could of removed the O ring seal on the fuel pump?
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
