Hey Guys so i just picked up my N/A R32.
I'm looking at doing Oil and filter change, preferably everything, because there was no previous service histories,
Now just a few questions.
How common are the Rb20DE N/A R32 Manual ?
What kind of petrol do i fill it up with ?
Unleaded or Premium , does it say in the book ?
What Kind of Oil do i use ?
10-40w ?
Sorry Guys, Just need a breif explanation.
What are common problems to look out for ?
Does a GTST Gear box fit the NA Version ?
And what pipping sizing are the exhaust and will a GTST muffler fit on mine ?
cheers, sorry for all the noob questions.
https://www.sau.com.au/forums/topic/348044-rb20de-questions/
recently bought one myself man.
mine came with a 2.5'' exhaust system, feels like i'm loosing a little power at the lower end, i'd go with a 2.25'' system for optimal performance.
As for juice, I've been filling up with premium since i got it, havn't run it on normal unleaded before... so not too sure there.
10-40w ?
1: manual natro r32's are common. i'd say just as many manual versions as auto, if not more
2: 10w40 oil should be fine.
3: you could use 91 octane fuel, however my suggestion would be at least 94/95 octane (E10 should be fine for this), and 98 is preffered.
4: most common problem would be coil packs arcing out from old age (resulting in misfires)
5: gts-t gearbox will bolt to a natro. the gts-t box is a stronger box, but unless your box is stuffed i wouldn't waste the money.
6: gts-t exhaust should fit on without much hassle. as said above, if you go an aftermarket system i'd suggest a 2.25" system as said above.
I used to run my RB25DE on E10 95ron with advanced timing, never had any detonation (n matter how far I advanced the timing) used to run fine.
Would probably be OK on 91 with standard timing, but E10 95 is just as cheap and it's worth running the higher ignition timing for that little extra grunt. I actually felt the tiniest drop in performance switching to BP98 before adding a turbo, but have no figures to back it up (just felt less responsive).
  On 22/12/2010 at 2:21 PM, TyresBro said:
Stupid question but how do you know your engine is pinging?
Thats not a stupid question haha, i was about to ask the same thing aswell.
Also, there is a fan that fan's the radiator , can i get rid of it ? and if so what do i replace it with ?
cheers, cause i see most tuned cars have slim line fans, but cause this fan is located on the block thought it worked diffrently, cheers.
You can hear pinging, like a quick flick of a tin can, or if it’s bad like a marble in a tin can... You can get knock warning devices, you can see your knock reading on SAFC and some after market management. The ecu also monitor's knock so you can feel it drop power/hesitate as well (providing all your sensors are connected and functioning).
The stock radiator/engine fan is called a clutch fan, in older age they tend to seize on a bit, make your car sound a bit like a falcon or hilux (windy revs) and steal a bit of power. You do need some sort of fan for your radiator, a good replacement is a temperature controlled electronic thermo fan, I have these on all my cars (inc twins behind a FMIC and a single 7” behind my R34 SMIC). They are noisy when they are on, but the motor is happier & quieter - plus I have lost 2 radiators and one water pump to seizing clutch fans in the past.
only bad pinging is audible. a lot of the time the car might be pinging and you won't hear it. on a stock ecu though, if the knock sensors are working properly it should retard the timing a bit to reduce pinging.
the stock clutch fans, when working properly, are the best option to use. they draw much more air than most thermo fans. there are plenty of high HP cars that still run them. people seem to think that thermos don't draw any power from the motor, but then add resistance to the alternator, which is run by the engine, so they still do drain a bit of power. if you do decide to run a thermo setup then my advice is to use the setup off a car that has them from factory, such as late model falcons, or fwd cars. these are often much more powerful than aftermarket ones, and the fact that they come with ready made shrouds you know that they are going to do the job well.
Hi guys, i got another question, when i rev slightly above 1k to 1.2ish , the car starts vibrating, is this normal ?
and i think the i might hear a pining sound, but apparenlty the previous owner said its a water pump sound ?
i dunno if its bad to drive it on this.
so whats the go to fix the pinging ?
Hey there mate, im in your position and i recently bought one aswell auto looking to convert it to manual. Automatic goes horrible and im not suprised. I couldnt seem to find many around non turbo let alone manual. i found one or two but they sold within a few days. Anyways goodluck with your questions as it may help me aswell, cheers
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
