Da Bitch Is Back
I know we gonna need it.
But wires etc, i'm lucky. All mine (being R31) are not there etc. And the bay has a slightly different design.
But mine sit's VERY low. So i wont need to move the P/S stuff luckily. Just need to make a add-on to my haet shield that i've already got.
Gonna be good fun. How does it feel?
Nice and responsive?
I was very surprised how much low down torque it has. U can drive in heavy traffic changing at 3000-3500rpm and it feels like a stockish car, but more than half throttle near 4000rpm and the turbo come on nice and hard.
I havent had a chance to test it out properly yet, need to find a nice cough*private road*cough to open it out.
I had 1 print out of the dyno graph but it got wet and smugged on sat when i was moving some stuff from my car to the garage and i left the graph on the bonnet and it started to rain and it got farked up.
  • Replies 78
I had an etag sitting on the dash on the way back from the skidpad day yesterday, and merging off the the tulla freeway on the westgate freeway i went from 5th to 3rd and gave it a bit of curry upto 6000rpm and the etag flew straight between me and the misses and hit the back windscreen rather hard. I shat myself if it hit me or someone in the backseat in the face it would have left quite a bruise, so theres a few g's when the turbo gets on full song.
Looks hot Denham. I'll be taking my car down to ICE aswell for some upgrades, Gt3540 turbo, ext gate, injectors, rail, pump and power fc but I'll be utilising the standard exh. maninfold, aiming for similar power as to what you got. ;)
lol, it does fit I've had an adapter plate made up. I've trial fitted it and seems to be fine. sits nice and low, though I don't know how responsive it'll be. If it turns out crappy I'll just have to go for a custom high mount setup, and not be tight ass... ;)
lol, it does fit I've had an adapter plate made up. I've trial fitted it and seems to be fine. sits nice and low, though I don't know how responsive it'll be. If it turns out crappy I'll just have to go for a custom high mount setup, and not be tight ass... :D
A 3540 would be very laggy even with a proper manifold i recon, but it could push u over 400rwkw with cams, headwork etc.
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
