Faulty Crankshaft Position Sensor
So i have had an issue with this for some time now, but i really can't afford to fix it. New from Nissan cost $700~800 and then the mechanics cost would probably bring it to $1100~. He said (the mechanic) that you can try find a second hand one... but i really don't think that's a great idea...
So pretty much i am looking for a easy solution.
Problems that occur with it;
(On random occasions)
During idle the engine malfunction light will pop on, and so the fun begins.
Idle, revs drop almost to 0 and car will tremble profusely.
Noise change, sounds like its constantly coughing. (or the engine is flooding)
Slow down! The car will struggle to accelerate.
If someone knows of a person or business i may be able to see, preferably around South east i would be extremely grateful!
I have tried looking around, but usually its the same answer.
Otherwise its reasonably safe to leave it unfixed right? Not like it can really do any harm..
https://www.sau.com.au/forums/topic/348078-faulty-crankshaft-position-sensor/
Do you mean the crank angle sensor? CAS?
Just get a second hand one for $50-$100. Make sure you don't over tighten the bolts that hold it on because that can lead to failure.
Or if you remove the timing belt cover and drive the car like that, make sure you use a few washers to space out the CAS.
They seem to fail by putting to much force onto the spindle inside of it and it seperates from the wheel inside.
Easy way to test it is to remove it from the car and spin the spindle. It should spin very freely and not make any noise. If it is a bit ruff or feels like there is sand in it (it is actually metal shavings) and makes a bit of a grinding noise than it is definetely on it's way out. Once it fails completely you will not be able to start the car.
Thanks for the information! I will give that a go, no noise like the one you mentioned as of yet, and yeah crank angle sensor sorry. The mechanic had given me the wrong information.
Much appreciated :wub:
No worries man.
I had mine fail on me while at a friends place with a pissed of ex gf at the time. Car wouldn't start and I couldn't figure out why. Rage doesn't begin to describe that night.
So yeah, I realise how annoying CAS' can be :P
do u know what the fault code is when the engine light comes on.? r34's have issues with coil packs, which could also be your problem, dodgy coilpacks in r34's bring up a ignition signal fault code. im guessing its a r34.
It is an R34. Well the thing is i was told originally by two mechanics that it was the secondary coilpack. The little computer (the engine scanner) changed from the first scan.
The order of scan that detected fault:
Check Crank Position Sensor
Check Cam Position Sensor. (Faulty may effect performance).
I don't remember the fault code for the coilpack. I am thinking it was code 21? But not 100%
  • Like 1
Yep 21 is ignition signal i.e. coil packs.
I had a stuffed CAS with similar issues as to what you describe above. Mine cost around $500 from memory (parts and labour), they rebuilt it with parts from another CAS.
I'd certainly get it fixed, it's no good for the engine driving around with a malfunctioning CAS.
Just to update, this is my third mechanics results. Kinda seems like he is confident about it.
This is the scan:
Code001:
P132 IGN SIGNAL-PRIMARY
It is costing almost $2000 to fix this.
I was told to replace all the coils. After being dicked around twice before i am a little worried about this. So hard to find good mechanics these days... So only one is failing, i can see a upside to changing all 6. But $2000 for them feels a bit steep.
I will be going to another mechanic who is meant to be quite trustworthy. I guess the adventure continues.
I appreciate all the help guys.
This is the scan:
Code001:
$2000 for 6 coilpacks? wtf mechanic are you going to. Any import mechanic knows about Splitfire coilpacks which sell for $300-$400 brand new??
Stop messing around with dud mechanics and get over to http://www.revzone.com.au/contact-us or http://recustoms.com.au
/end
What you describe sounds like a problem I had on my 33 with the CAS. Turned out to be a crack in the mounting bracket that would let the CAS rotate by 2掳 or 3掳. Putting your hand on the CAS and pushing it towards the cam would change the "note" in and out of tune. Bracket was $20.oo I think.
    • Wrt the engine, you're very much limited by 'production quality' as to how much extra power you can extract from them (I'm talking i6 red-motor) -- a lot here depends on how 'authentic' or 'period correct' you want the modifications to be... ...I'm too old... <grin>...the first true performance engine Holden made, was in the HD/HR models ~ this was the 'X2' performance pack...it came with twin downdraft strombergs on an otherwise unimproved intake manifold, with a two piece exhaust manifold (reckoned to be as good as extractors)... ....these engines were built upon the '179HP' cylinder block, which included extra webbing in the casting to make it stronger and less susceptible to block distortion... The next performance i6 came out with the HK Monaro (also found it's way into the LJ GTR Torana ... the car I wish I hadn't sold)...it had pretty much the same manifold setup, but was built against the '186S' block...this block retained all the extra webbing of the 179HP block, but added a forged steel crankshaft (instead of the stock cast crankshaft), because it was possible to snap the crank... ...apart from the inherent weaknesses in the stock (cast crank) blocks, the next limiting factor is the cylinder head porting & combustion chamber design, and the actual valve sizes. Back in the day, you could buy a 'yella terra' cylinder head (from stage 1 to stage 5 gradients), and this was the way to get serious power out of them -- with the extra breathing of these heads, you could fit a triple SU or DCOE Weber setup... ...obviously, these mods were a waste of time on a stock cylinder head/camshaft grind. My housemate rebuilt the i6 in his VH dunnydore about 6 months back -- this is a 186S block with the 12port 2850 blue motor head and intake/exhaust manifolds, with a dual throat Weber off an XF Falcon mounted on an adapter plate ; it's not a bad makeup...got more torque & fuel economy just light-footing it about on the first throat, but stand on it and it makes more giddy-up than the standard 2850 blue motor that it replaced. Personal note: I'd just fit an RB30 and be done it it 馃槂
    • Thanks for sharing. That's a great video! My buddy is doing the same thing on his build (S chassis struts and towers). He's building an S14 with billet RB30 shooting for 2000whp... a race car with a TH400 just like this video. For a road car I just couldn't go this route as the strut has to be almost vertical and the caster is not going to pivot correctly (let alone camber gain). You think the R32 frontend is bad, wait till you put a MacPherson strut on without modeling it all in Solidworks to check geometry. I'm not saying it's a bad way to do it but I'd be really curious to see how it affects the geometry.
    • Hey Christof and welcome!  Sounds like an awesome project! I'm not sure many of the regular users on here would know much about the HK but I could be wrong.  Looking forward to updates.
    • As long as its NOT a HyperSHITtune, youll be fine.
    • First time visitor and currently getting ready to start work on my HK Premier.  Its all stock, 186 with 3 on the tree.  The only mod i have right now is extractors.  I am hoping to get some guidance on slightly modifying the engine to bring a little more power. Just going for a nice, comfortable cruiser.  The car is very straight, however i have been out of the country for 20 years and its been gathering dust at a family farm.  Will be doing quite a bit of body work to cut out some small rust areas (frnt quarter panels and a few other small bits) and fix up the paint.  Will be redoing the interior (its currently black and the seats are in real need of recovering and respringing the driver side (its front bench seat).  The dash needs a little TLC, but no real damage.  As my heater has degraded I am considering fitting something after-market that will be both heater/AC (recommendations here are always welcome). Wanting something discrete that will allow me to use the same controls and not be obvious once inside the car.   For the engine, i have been told i could consider upgrading my cam (imagine i would need a new head as well) and putting a new carby (currently the original stromberg).  However not sure what is going to be the best route.  Would certainly welcome any comments/suggestions.  As  a final step I am looking at changing the wheels. Current hubcaps are in dire need of refurbishment or replacement (imagine its a bit like hens teeth).  Thinking of some clean/classic looking mags (7-inch should be more than enough - not going for a large change in look).  Welcome any comments/advice and of course any questions.
