Faulty Crankshaft Position Sensor
So i have had an issue with this for some time now, but i really can't afford to fix it. New from Nissan cost $700~800 and then the mechanics cost would probably bring it to $1100~. He said (the mechanic) that you can try find a second hand one... but i really don't think that's a great idea...
So pretty much i am looking for a easy solution.
Problems that occur with it;
(On random occasions)
During idle the engine malfunction light will pop on, and so the fun begins.
Idle, revs drop almost to 0 and car will tremble profusely.
Noise change, sounds like its constantly coughing. (or the engine is flooding)
Slow down! The car will struggle to accelerate.
If someone knows of a person or business i may be able to see, preferably around South east i would be extremely grateful!
I have tried looking around, but usually its the same answer.
Otherwise its reasonably safe to leave it unfixed right? Not like it can really do any harm..
https://www.sau.com.au/forums/topic/348078-faulty-crankshaft-position-sensor/
Do you mean the crank angle sensor? CAS?
Just get a second hand one for $50-$100. Make sure you don't over tighten the bolts that hold it on because that can lead to failure.
Or if you remove the timing belt cover and drive the car like that, make sure you use a few washers to space out the CAS.
They seem to fail by putting to much force onto the spindle inside of it and it seperates from the wheel inside.
Easy way to test it is to remove it from the car and spin the spindle. It should spin very freely and not make any noise. If it is a bit ruff or feels like there is sand in it (it is actually metal shavings) and makes a bit of a grinding noise than it is definetely on it's way out. Once it fails completely you will not be able to start the car.
Thanks for the information! I will give that a go, no noise like the one you mentioned as of yet, and yeah crank angle sensor sorry. The mechanic had given me the wrong information.
Much appreciated :wub:
No worries man.
I had mine fail on me while at a friends place with a pissed of ex gf at the time. Car wouldn't start and I couldn't figure out why. Rage doesn't begin to describe that night.
So yeah, I realise how annoying CAS' can be :P
do u know what the fault code is when the engine light comes on.? r34's have issues with coil packs, which could also be your problem, dodgy coilpacks in r34's bring up a ignition signal fault code. im guessing its a r34.
It is an R34. Well the thing is i was told originally by two mechanics that it was the secondary coilpack. The little computer (the engine scanner) changed from the first scan.
The order of scan that detected fault:
Check Crank Position Sensor
Check Cam Position Sensor. (Faulty may effect performance).
I don't remember the fault code for the coilpack. I am thinking it was code 21? But not 100%
  • Like 1
Yep 21 is ignition signal i.e. coil packs.
I had a stuffed CAS with similar issues as to what you describe above. Mine cost around $500 from memory (parts and labour), they rebuilt it with parts from another CAS.
I'd certainly get it fixed, it's no good for the engine driving around with a malfunctioning CAS.
Just to update, this is my third mechanics results. Kinda seems like he is confident about it.
This is the scan:
Code001:
P132 IGN SIGNAL-PRIMARY
It is costing almost $2000 to fix this.
I was told to replace all the coils. After being dicked around twice before i am a little worried about this. So hard to find good mechanics these days... So only one is failing, i can see a upside to changing all 6. But $2000 for them feels a bit steep.
I will be going to another mechanic who is meant to be quite trustworthy. I guess the adventure continues.
I appreciate all the help guys.
This is the scan:
Code001:
$2000 for 6 coilpacks? wtf mechanic are you going to. Any import mechanic knows about Splitfire coilpacks which sell for $300-$400 brand new??
Stop messing around with dud mechanics and get over to http://www.revzone.com.au/contact-us or http://recustoms.com.au
/end
What you describe sounds like a problem I had on my 33 with the CAS. Turned out to be a crack in the mounting bracket that would let the CAS rotate by 2° or 3°. Putting your hand on the CAS and pushing it towards the cam would change the "note" in and out of tune. Bracket was $20.oo I think.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
