Anyone had their stock radiator recored at all? Am weighing up the options and costs for getting a new OEM one (Koyo) or my old one recored. The tanks look to be ok, so will take it to a radiator factory tomorrow and get some more advice.
Just wondering what others have done when they needed to replace it. I wouldn't mind a slightly thicker core, but I guess the stock one is still pretty good if you're not heading to the track right?
https://www.sau.com.au/forums/topic/348095-new-vs-recore-radiator/
I priced getting mine recored and it turns out cheaper to buy an aftermarket one.
A new double core 32mm i think was about $280+..and you can get a 52mm aftermarket for less than $230..A 42mm is even cheaper.
stock one is fine for most applications, but if your going to spend the money why not get something better... :D
Edited by Arthur T3
the ASI ones on ebay are supposed to be good for the money
i bought a cooling pro one from justjap
its ok but was a bit exxy at $370 i think (exxy for something that is still made in china)
I've looked on ebay and there are a few options. The ASI ones do look good value for money with there being a 42mm and a 52mm one for around $190 each. But they don't appear to have an auto one.
But this brings up a few other things though too. Like will they fit together with the stock fan and fan shroud, or do I then have to replace those as well?
There are also some OEM ones on ebay which look identical to the stock radiator. Though it might not cool as good as the 42mm or 52mm one, I'm never going to track my car, and would rather have it look more stock than riced out. I think one of the ones I found was a Koyo branded one, for under $300. I don't know much if anything about radiator brands, but isn't Koyo a pretty decent brand?
Will know more tomorrow on how much it will cost to re-core my old one. Then from there at least I have some price comparisons.
I'd really like something that looks stock, but maybe is thicker than 25mm.
Arthur, where is this 32mm one you were referring to?
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
