I just installed mine on Friday night. I had to modify the actuator mount to make it fit without tapping the tower in. Got a die grinder and elongated the holes on the actuator bracket and then just slid it up until it cleared the strut tower.
Also for the coolant line on the body side of the turbo I took it off the block and attached it to the turbo then bent it into position on the block end, makes the job so much easier. Took approx 5min to get the water lines on, just make sure you undo the pipe clamps holding them to the block like Stao said.
https://www.sau.com.au/forums/topic/348097-atr43-g3/page/2/#findComment-6670104
Just quietly, these turbos are a HELL of a lot easier to get on and off if you spend a bit of extra cash and make up some braided water lines for them. I can get mine off in well under an hour these days, without the helping hands from mates. I spent about $60-$70 on the Speedflow fittings and braided line that I needed and put them together myself (anyone installing a turbo can put together braided line).
Food for thought.
https://www.sau.com.au/forums/topic/348097-atr43-g3/page/2/#findComment-6681857
  • 1 year later...
  • 1 year later...
Gonna bump this cause I think it's relevant
So I've been installing my ss2 and have an issue with the water lines.
The one on the engine side. I assume is feed is touching a bolt on the turbo. Will this be an issue? Vibrations etc.
The feed on the body side looks like it doesn't reach AT all. I'm thinking I'll just get a braided line made up cause it'll be easy to get too. Or I just realised above has said to attach to turbo first.
So my question really is about the one on the engine side. Or how do I go about.connecting a braided line to it being that the line runs to the back of the block.
Edited by MatthewT85
https://www.sau.com.au/forums/topic/348097-atr43-g3/page/2/#findComment-7651875
I just finished installing my ATR45 which is bigger than the SS2 had to do the following
Unbolt brackets from the engine side holding lines to the block
Undo water line off the side of the block
Bolt the water line to the turbo
Bend/Stretch the water line a bit to get it to get back to the block
After doing the above its fine, have a few mm of room between the turbo and the line but it fits none the less.
Tao can confirm but that's pretty much what he told me to do and it worked
https://www.sau.com.au/forums/topic/348097-atr43-g3/page/2/#findComment-7651906
hmmm ill have to look at it again tomorrow and try that line again,
i guess ill have to look at the other one and see if theres a way to get it away from the bolt too
If the exhaust and inlet housings are in the correct positions just loosen the 13-14mm? Bolts around the housings and then you will be able to rotate the center enough to clear the bolt [emoji106]
https://www.sau.com.au/forums/topic/348097-atr43-g3/page/2/#findComment-7651924
ok i think i get what you mean,
take the turbo out and loosen bolts on both sides, intake and exhaust, and that will allow me to rotate the core on its own but the actuator will keep the two sides in the correct positions?
I guess ill rotate that side pictured up about 10mm and try again, that does sound like it will help with the other side as the line sits ALOT lower and from mem the side i could connect was higher.
Currently its all set at 12-3-6-9, if you look at it like a clock
I guess its just something ill have to try.
https://www.sau.com.au/forums/topic/348097-atr43-g3/page/2/#findComment-7651955
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
