Took my car to Scotty's house over the weekend to get Customer dump, front pipe, and hiflow cat + Legalis R fitted. Picked it up last night. It sounds sooooo sweet!
Also fitted a new hi flow air filter (Blitz SUS Power)...thanks to Scott I now know how to pull out the airbox!
things noticed:
Fuel economy improved - since I the exhaust has less restriction, the engine doesn't work as hard to maintain cruising speed or accelerating. I noticed that I used to hover around 2200 RPM when i was doing 100kph on the freeway, where as now its about 1800 RPM.
Boost comes on earlier - the turbo used to start spooling after the 2500 RPM mark, whereas now it spools at 2000 RPM.
Car definately seems to pick up faster also.
The only downer (to me - this is my 1st turbocharged/exhaust'ed) is obviously the noise. Idling noise and full throttle sounds great, but I've still yet to get used to the constant low gumble when i'm cruising, whether it be at 60 or 100...
Scotty also noticed that the rear transfer case (?) is leaking fluids badly. More $ to spend dammit!
Overall, very happy with the results. Huge thanks to Scotty and Aaron who helped to make this happen!
BTW wheres the cheapest place to get Matic J in Melb?
Edited by ironpaw
https://www.sau.com.au/forums/topic/348160-new-exhaust/
Nice :)
Matic J can be purchased from any Nissan dealership... or you could get the Nulon fluid which is compatible with both Matic D and Matic J (so you can use it in your transmission, transfer case, power steering and ATTESSA)
https://www.sau.com.au/forums/topic/348160-new-exhaust/#findComment-5599438
Scott did most of it!
but glad your happy. you should thank my Girlfriend for looking after his kids so we could get it finished !!:wave:
Hmm say thanks to her for me...soz forgot her name LOL...
Can I mix Matic J with Nulon stuff? I don't want to flush and refill...
So I just top up the trans fluid and this should keep the fluid loss at bay until I get the seals fixed?
Would any transmission joints be able to fix the seal?
Edited by ironpaw
https://www.sau.com.au/forums/topic/348160-new-exhaust/#findComment-5599486
Where on the transfer case is it leaking from?
Personally I am not much of a fan of mixing fluids, so I guess if you are just "topping it up" get the Matic J
https://www.sau.com.au/forums/topic/348160-new-exhaust/#findComment-5599729
I have the same Legalis exhaust, with a dump pipe, 3" front pipe & high flow cat on my car, & I too had the drone issue.
I swear hand on heart, my exhaust has become quieter over the last 2 months.
I'm sure it's not a case of getting used to it; even my missus asked if I'd done something to make it quieter! Give it time, maybe you'll have the same result.
https://www.sau.com.au/forums/topic/348160-new-exhaust/#findComment-5600368
Anyone wanna load up FAST and tell me wats the part number for the seal?
go to nissan and ask for matic J they always have it in stock.
yeh once the inside of the exhaust gets filled with that black soot stuff, it works as an inslator. giving a nice deeper note, and quieting that drone.
https://www.sau.com.au/forums/topic/348160-new-exhaust/#findComment-5600386
Theory is that as AronNM35 mentions "black soot stuff" will build up in the new back muffler. A lot of the stuff that will build up would previously not made it that far back in the exhaust as the 2 cats would have looked after these wastes better that the one hiflow. The black stuff would be mainly carbon from partial combustion of fuel.
Have replaced from turbo back on my ARX and just left the original muffler for now - it also seems to have become quieter over just 600km and was told this would happen.
Maybe you could just turn up your music for a few months Ironpaw?
https://www.sau.com.au/forums/topic/348160-new-exhaust/#findComment-5600489
the seal probably isnt much money, and i cant imagine the labour would be all that much to replace it, however if you need a replacement transfer case, let me know, ill have my 'spare' available shortly :P
also, i like hearing about nice exhaust notes. im hoping to have one soon too!!
https://www.sau.com.au/forums/topic/348160-new-exhaust/#findComment-5600502
lol Black Soot Stuff= What he said ^^:ph34r:
well pull it apart n put the list up lol everyone wants things!
https://www.sau.com.au/forums/topic/348160-new-exhaust/#findComment-5600569
LOL I know, but I need the part number for the seal so I can get it from Nissan! I don't believe I can just go in and be like "hey gimme a transfer case seal for my sutegea!!!!"
https://www.sau.com.au/forums/topic/348160-new-exhaust/#findComment-5600687
you just need your chassy number.. and go and explain it to them. they'll pull up a diagram of the transfer case all pulled apart.
They'll find the part. but you can only go to Ferntree gully nissan.
https://www.sau.com.au/forums/topic/348160-new-exhaust/#findComment-5600709
Could be the soot, but it may also be water in the resonator.
You can if you give them your VIN
Give either Ferntree Gully Nissan or Frankston Nissan a call
https://www.sau.com.au/forums/topic/348160-new-exhaust/#findComment-5600711
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
