Could be the soot, but it may also be water in the resonator.
Unless he does really short trips continually I would have thought it would get too hot for water to condense in the resonator?
With just the hiflow cat (instead of the one in the dump and one in front pipe) should be finding it gets hotter further back in the exhaust system now.
Don't have a resonator in atm and is just 3" straight throught to original muffler and it is getting quieter so think the soot build up is most likely settling it down.
It is more due to the design of the Legalis (and the original Nismo for that matter).
You can see in the pic below that there is a resonator off to the right of the main pipe, this is the one I am referring to.
For some reason, it is quite normal for this to have some water in it after a bit of use (have even seen some guys state it is the reason they have put them up for sale on Yahoo - bit dramatic if you ask me)
Have seen that weird little growth off the side before and have wondered how much it might help quieten the system.
Guess it would take a bit longer to heat this part up as the hot gas doesn't flow straight through it so would stay cool enough for water vapour to condense a bit longer than the rest.
Maybe they should put a drain plug in it!
apparently i read in another thread that it sends a pulse noise/signal, when it rebounds off the end, back to the exhaust cancelling out most of the sound(correct me if im wrong - iamhe im sure you will anyway) which could be possible. kinds of like in/out of phase or cross phase in audio i guess.
It helps to quieten it quite a bit (although I have not cut it off my Nismo to check - nor will I).
Here are a couple of clips I put up using a digi camera. As you can see/hear, neither are particularly loud.
Both have a very, very similar design although the pipe to the resonator is angled slightly differently and the rear muffler is completely different.
Keep in mind the dump on this thing is massive, around 4 inches wide oval under the passengers feet. It will definitely sound different and slightly louder.
The drone at 2000 revs is a pain, very hard to get rid of. I cruise on 2500 now and don't hear it.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
