what engine/turbo/suspension setup are your running btw..??
Well..
Engine & Turbo
Rebuilt RB20DET (metal gaskets, machined crank, honed rods, new pistons)
HKS Turbo (model has slipped my mind as was done before I bought car)
Sard 550cc injectors
Splitfire Coils
Z32 AFM
Nismo Fuel Pressure Reg
Nismo Fuel Pump
FMIC
Greddy Dump Pipe
3" Turbo-back Exhaust with 4 1/2 inch performance cat (3 inch inlet/outlet)
HD Clutch
GReddy short shift
GReddy Profec B II EBC
Apexi turbo timer
Stock gearbox
Stock LSD
Nistune
Suspension
Stock
Fronts fine
Rears are shot
May have left one or two things off but thats about it
so why are running all of that brand name gear and yet running crap tyres and stock suspension...
you dont know what turbo your running? and a HKS not making boost until 4300rpm, thats not that great...
that would feel like driving a sponge... makes no sense what so ever to not do suspension work first...
Ok many things...
1) It makes boost at 3200rpm, full boost at 4300rpm
2) Have you seen the price of rubber these days? And...i'm not doing any track work yet...Bridgestones are fine if everyone is saying that get same/more traction with sumitomos
3) HKS GT28R or something
what about suspension & brakes and, I dont think just adding coilovers is called an upgrade to the suspension on their own without being setup,
then there is bushes and alignments (and some sort of adjustable parts, castor & camber), and setting up suspension and alignment does not mean going to jax tyres, I mean a serious alignment by a proper suspension workshop...
Yeah I have the stock coilovers that came on all R32 GTSTs
4 pots on front, stock discs
2 pot on rears, stock discs
I think I'm going to...
Tune
Coilovers (36 way adjustable eliminating need for adjustable castor/camber arms)
Wheel allignment
Back to forum for results
  • Like 1
  • Nope 1
those tyres are hopeless, get yourself some kumho ku36 or federal 595s at the least.
if you have stock rear suspension i dont see how u could have negative camber unless someone has put lower springs on the factory strut.
that power shouldnt promote any wheelspin on decent tyres and correct wheel alignment.
not having a dig just letting you know you could easily be putting this power and slightly more to the ground IF you buy decent tyres and work out why u have negative camble on untouched suspension??
umm wow, who told you that one....
you need to read and learn way more before you do anything...
stock 16 year old brakes - fail
stock 16 year old suspension - fail
thinking BC coilovers will do everything - complete idiocy
seriously a car with only 150rwkw but a half decent suspension and brake setup would embarass you....
coilovers dont do castor adjustment on any car..., do you even know what castor is?
36 way adjustments in your hands would mean it would clearly be setup wrong.
Tune
Wheel allignment
no (thats wrong) Adjustable coil overs are height and damper adjustable.
you need adjustable arms if u wan to pull the camber back out of a lowered car.
caster is generally making reference to the front castor angle (you dont need to be worrying about this)
Edited by tm_r33
no adjustable coil overs are height and damper adjustable.
You're talking out your arse son.
http://www.skylinesaustralia.com/forums/topic/113180-apexi-t-max-shocks-for-r33-height-and-damper-adjustable/page__mode__threaded__pid__2090889
Just pulled the first height and damper thread I found.
Edited by plan-b
except im not. i have adjustable arms in my car son.
aside from front coil overs to suit nissan sil/180. which can adjust camber.
how exactly do u plan to adjust camber and castor on the rear of your skyline using your coil overs???
No its a shit take...what you reckon?
Quick to jump on the defensive much?
Oh...is this in your R31?
Nice cover up. Pity he's a moderator and can clearly see what you originally wrote. Abusing the mods will get you no where.
the reason I asked about a piss take is because it's the third thread in almost as many weeks I have read with someone asking this question. I have X amount of power and I keep skidding everywhere. Granted, the last guy was in the wet. I was only checking to make sure you weren't having a joke.
There is ample responses above to give you the information you already wanted to hear. You only wanted people to tell you what you already knew.
1. Learn to drive
2. If you can't handle the power, down tune it until you get used to how to control it
3. Put on some better tyres
option 3 will pretty much cancel out options 1 and 2.
too much power, not enough experience, and poor suspension/tyres
yeah you will need more than some you beaut coilovers that come in orange to actually make the suspension better....
your wrong, we're right...
read it properly
i put brackets in the post so u understand what i meant lol. im only offering my insight mate.
NO, (coilovers dont adjust camber castor) adjustable coil overs are height and damper adjustable
Edited by tm_r33
1. Learn to drive
1) Did you know that people have reasons for asking questions? Apologies for reacting the way I did but smart ass comments aggrevate the shit out of decent people.
2) Just because you can't see the validity in someone's point doesn't mean the thousands of other forum members don't...as can be seen from Bubbas comment earlier.
3) when reading text, tone and manner cannot be interpreted so the way you read something may not be the way it was intended to be read.
4) Putting on better tyres will eliminate my inability to know how to drive (just showed your maturity there)
5) Never said I couldn't handle the power, never even said I didn't like the wheels spin, and never said I couldn't drive
6) good to see your a mind reader. might PM you next time I need to make a really important decision.
7) Lucky number 7...means I stop wasting my time typing responses to your shitty talk.
Over and Out...
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
    • I've been quietly following this thread for ages, but this one got me. Since my ADHD diagnosis (and associated learnings and prescription) I'm way less inclined to wade into forum yarns when there are better things to do with my time, as half the time I'd end up in some kind of forum debate even if that wasn't my intention. I've not lost the ADHD "superpowers", just am a lot better at directing my hyperfocus into slightly more constructive things, but haven't stopped quietly lurking in here in my spare time.
    • Stripped the tank down and gave it a good scrub. It came up really good! Not sure if I'll just put it back in like that or give it a blackening treatment (such as Bowdens The Black Box). That might give it a matte look so might just run it as is.
    • @MBS206 Ha ha, yeah ADHD is a daily battle to not get drawn in to doing things you want to do that you know you shouldn't do!  Every single time I walk into my shed I end up doing something I started the day having zero intention of doing! I keep mentioning the 1 step forward, 3 steps back scenario and I'm tipping people that are blessed with ADHD (yes, blessed) are the worst at that!
