1) Did you know that people have reasons for asking questions? Apologies for reacting the way I did but smart ass comments aggrevate the shit out of decent people.
2) Just because you can't see the validity in someone's point doesn't mean the thousands of other forum members don't...as can be seen from Bubbas comment earlier.
3) when reading text, tone and manner cannot be interpreted so the way you read something may not be the way it was intended to be read.
4) Putting on better tyres will eliminate my inability to know how to drive (just showed your maturity there)
5) Never said I couldn't handle the power, never even said I didn't like the wheels spin, and never said I couldn't drive
6) good to see your a mind reader. might PM you next time I need to make a really important decision.
7) Lucky number 7...means I stop wasting my time typing responses to your shitty talk.
Over and Out...
No, you are wrong once again. I am very willing to help. I offer advice on these forums all the time. Before I waste my precious time answering every silly question out there I merely asked if you were taking the piss. A simple 'NO' would have sufficed but you were too quick to lash out with your arrogant attitude.
We can keep our track car stable at 6000rpm with 550hp at the wheels. It has good tyres. It has average suspension. If I put my foot all the way to the floor, yes it will easily step sideways in 4th at 110. No you can't f**king drive
I wsn't being a smart ass in my first post
So here's my big 'f**k OFF' to you
Hi Everyone
I have a R33 that is fulleh sic, and makes 315rwkw+ and 720nm of torque from 3200rpm.
I seem to fry 1st, second, and most of third, fish tailing past 100kmph.
Can anyone help me? I mean, I'm really cool and all, because I can fry my shit tyres that are only running on about 20mm of the tread because my camber is fulleh sic, etc.
Anyway, I'm cool everyone, my car is teh sic!
lol.
oh, and I raise you all: +2.
Well Said!
My money is the car will end up crashed soon enough... hopefully the OP will be ok....
Can I get in on that?
Hi Everyone
lol.
This made my day!
IMO: sell the car. and buy a couple of hyandai excel's instead. although you might get torque steer. but you could always lower the boost in an excel
Torque steer dance?:bunny:
  • Like 1
Despite all the garbage, has anyone considered maybe he is single spinning??
A worn viscous LSD will generally slip when less load is applied, IE loose surface or when the wheel speed is close enough to engine speed for it not to load up. Lighter load on a worn or slipping LSD could see if flare 1 wheel on that sort of power (admitedly not alot).
Try buying a $1 shim from nissan and popping it in.
  • Like 1
lol im now hanging round for the laughs.
do the new excells come with traction control that ( for everyones safety) can not be turned off??
Not if their running Super Man Bearing Garret GT984651231's i've been told they torque steer in 8th gear.
  • Like 1
BAHAHAHAHAHAHAH
Do you really think its safe to encourage him to pull his diff out, knock out drive shafts, remove center, take off crown wheel, install shim and then try to put it all back together in a safe working order.
i have shimmed plenty but i wasnt guessing either. i understand how diffs work/engage and knew the torque settings, back lash setting etc.
i can see a post in near future entitled.... "so i shimmed my diff but then it locked up at 100 km/h and sent me into a tree and now im dead"
lol
BAHAHAHAHAHAHAH
lol
LOL
As opposed to I got hekticzz wheel spin at 5700 trying to race a V8 and hit a tree and now I'm dead
LOL
but he tuned the wheelspin out of his car remember...so he beat the 4.8 litre 1979 pushrod v8 but then for some reason his wobbling crown wheel jammed up against the pinion and parked him violantly against a tree. lol
LOL
Seriously,
I heard he was doing wheelie's when he planted his foot down at 100kmh. that was in his Front Wheel Drive, Super Man Bearing Garret GT984651231's excel without traction control.
i tried looking for a modded excel but laughed to much.
looks like i came to the partay too late... ah well...
fwiw i run a 285rwkw rb25 which hits 20psi by 3400rpm. i run greddy coilovers, camber and pineapple bushes on the rear and a 1.5way locker. ( i also run the car @ 320mm)
in the dry i can plant all gears except 1st right through to my 7400 redline without a hint of wheelspin
you are running a less powerful, less responsive setup and have trouble getting traction, so what are the differences?
i run a locked diff, better tyres, less camber, better shocks, and pineapple bushes. i also have correctly matched shock/springs which i'm guessing you dont due to the comment about camber with stock shocks
fix all these and you should have no worries.
on ethanol i run 325rwkw and lose traction in second, but it's easily controlled with my right foot and dosn't bother me
also coilovers will not allow adjustment of castor or camber (with 180sx/s13 front camber adjust being an exception) for this you will need bushes or adjustable upper/lower arms
you need to get your car to a suspension workshop (not pedders)
i've concluded that this thread is as good as the thread made by the goose asking why he was getting beaten by everyone as he always drives r32 off boost
No, this one is definitely better. He spelled 'losing' incorrectly in the thread title
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
