Hey fellas,
Anyone have a issue with their gearbox opening when changing gears under power?
My last 3 R32's have all had the issue and it drives me insane and I'm yet to come up with a solution. I'm just about ready to tech screw the stupid thing closed forever :)
Any ideas/solutions???
Cheers
Simon
https://www.sau.com.au/forums/topic/348185-r32-glovebox/
Hey fellas,
And no, never had a problem with the glovebox either!
Edited by blind_elk
https://www.sau.com.au/forums/topic/348185-r32-glovebox/#findComment-5600102
lol well played.
actually yes I have exactly the same issue.
in my race car the dash and glovebox are a little crooked from the cage install. As a result if I close the glovebox straight up it does not latch properly, but it looks like it is OK and stays closed until the launch. If you push it to the right when you close it, it is OK. which is a long way of saying....check it is latching properly. When closed properly it never comes open even crashes
https://www.sau.com.au/forums/topic/348185-r32-glovebox/#findComment-5600265
LOL FUUUUUUUU
lol well played.
Yeah the latch seems to leave a few mm gap when it is in the "closed" position... When enough force is added (through brutal gear changes) it just squeezes through the gap.
The latch isn't opening, just dodgy clearances... DAMN NISSANS
Edited by SimonR32
https://www.sau.com.au/forums/topic/348185-r32-glovebox/#findComment-5602409
do the gloveboxes in the 32 slide into place (can you remove them by opening then pulling them up, or something like that). if you can, then it may be worth looking at pulling it out and putting a bit of plastic or cardboard at the bottom of the slot that it sits it so that the glovebox sits higher. this should make the latch have better contact. or have a look at the latch and see if can be moved up at all.
https://www.sau.com.au/forums/topic/348185-r32-glovebox/#findComment-5604459
I've had this problem. Bought a new glovebox and realised it didn't fix the issue so I just grabbed some pliers and bent some things in the latch... :mellow: It stays shut now
Thanks for the idea, I just got a set of plyers and bent the f**k out of it!
Now seems to latch and hold :)
https://www.sau.com.au/forums/topic/348185-r32-glovebox/#findComment-5607937
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
