Hey guys im looking for a Nissan Skyline R32 or Nissan Silvia s13 that's Non-turbo and must:
- Be manual
- Be registered in Victoria
- Have driven less then 185,000km
- Be mechanically good.
If it has some body damage it doesn't matter, as long as not anything major.
Send details and price through PM.
https://www.sau.com.au/forums/topic/348199-wtb-vic-non-turbo-r32-or-silvia-s13/
Hi, What is your budget. I have a S15 Autech Non Turbo.6 speed.has similar KW compare with standard S15 turbo.goes suprisingly good for a NA
Don't know how to PM with the new format. call me on 0433878905
Alex
Campbellfield Vic. 3061
Edited by Tim GTR
Hi, What is your budget? I have a S15 Autech non turbo with similar KW compare to a turbo, goes surprisingly well as a NA.please call Alex on 0433 878905
Hey mate got a R33 N/A has been built ground up no work needs to be done unless you want to drop in an RB25DET or RB26DETT engine later...
Throw me an offer if you like what you see
http://www.skylinesaustralia.com/forums/topic/335985-1995-r33-gts-4/
as said earlier, what is your budget?
i have an r32 4door, complied rb25 non turbo, manual, r33 running gear, all adjustable arms & links, coilovers, 5stud conversion, lsd, tints, brides, nardi ect. very fun and reliable car. ill be willing to drive it down to victoria for the right price ;)
0401 214 700 kevin.
cheers
Check this out mate, have seen this in person and my god its a very nice and clean example owned by a mature couple.
http://www.skylinesaustralia.com/forums/topic/347354-s13-nissan-silvia-qs-ca18de/page__p__5588711#entry5588711
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
