have recently removed my boost "t" and only gettin 5psi from standard solinoid only one vacc hose going from solinoid to intake searched for two days now and cant find anything here other than how to remove dual stage part by earthing.
(items removed to clear defect)
https://www.sau.com.au/forums/topic/348202-standard-solinoid-plumbing/
solenoid plugged in? if you do the hack to get 7psi all the time does this work or is it 5psi?
also do you have stock ECU? iirc if you upgrade the ECU, the solenoid wont work as its operated by the stock ECU.
easy fix is to put the boost T back on
Supply boost from intercooler pipe to one side of solenoid. Other side goes to plain T one branch to bov return pipe other branch to w/g actuator.. there should be a restrictor which i think goes in the boost supply line to the solenoid. if you are missing that you will have less boost. You can simulate the restrictor for test purposes by lightly clamping the supply pipe ( don't cut off the supply or your turbo willl boost astronomically and likely self destruct!!).
the w/g actuator is only 5psi in R33 and 12psi in R32.
to get more boost you will have to use your boost T or boost controller. using the stock boost solenoid with the high boost mod will give you 7psi rather than the 5psi then 7pis after 5000rpm or what ever it is if its working.
  • Like 1
you were gonna buy a VN instead of going and buying a $20 boost controller to get it to go to 7psi?
that makes no sense... why would you want to downgrade like that.
If you get the standard boost solenoid and plumb it up you can cut one of the wires and earth it straight to the chassis and have 7psi constant. Theres a tutorial on it somewhere
As for the bit about the restrictor? I havent seen that in an R33 but I think there is something like that in the 34's but not 100%
the boost solenoid has 2 ports close to each other and one somewhere else, Im pretty sure the 2 close together go to the cooler piping and the BOV return line, the other line goes to your W/G actuator. What was said above about tee-ing the solenoid to the W/G actuator on one side and bov return on the other should not be done. There will never be enough boost supplied to the actuator to open the wastegate if you do this and it will boost till it goes bang
but I may be wrong about how it is hooked up, havent had a stock boost solenoid for a long time. should be able to find photos on here somwhere, probably in the thread to do the 7psi constant boost earth mod.
Edited by 89CAL
For the vn remark i was comparin 5psi to being close to vn spec. Im trying to keep car defect free (after removal of this one) so standard solinoid will surfice for now. Thanks for your assistance. Next time i see full stock r33 gtst ill have look at how things are ment to be
Wouldn't happen to know the factory spring pressure of a R34? Got one here looking to go on my car, would like to know if I should modify it to run lower boost? (an aim of 7psi)
  • 5 weeks later...
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
