Hey all
Well my problem is that the old girl has a problem at idel but on when it is @ 1500rpm and starts to shudder and miss fire not really sure what the problem could be cos i changed the plugs about 6months ago and the coilpacks about 8 months ago, but the machenics i took it to said it was just the way that stageas run and they couldn't do anything about it, so it has stayed that way since it dosn't effect the proformance at all. but i guess it mabe a problem that could effect the engine later on down the track and just want to nut out the problem so it dosn't develope into something big.
any help would be much appreciated
thanks
Josh
https://www.sau.com.au/forums/topic/348215-series-2-idel-problem/
This is mechanic speak for "I'm a stupid donkey who spent my entire apprenticeship smoking cones in the toilet, instead of learning my trade.
Now due to my complete lack of functioning braincells, and the fact that the only tool I ever used at work was a mop, and I was quite intimidated by it; I now have no ability to troubleshoot anything more than the mophead falling off the handle."
Run far far away from this workshop, and find a mechanic who is actually prepared to engage his brain, and at least ATTEMPT to diagnose the problem.
Either that, or purchase a blue & white striped apron for him, so everyone can identify him as the butcher he patently is...
lol
might I suggest a few things and people can chip in with others I've missed:
ignition:
- coilpacks (checked)
- plugs
- plug gaps
fuel:
- IAC valve (clean it - see the DIY, unsure of differences with the NEO engine)
- MAF sensor - may need cleaning, or resoldering of pins (cut silicone out of the square, remove, resolder, re-silicone... in the DIY somewhere on SAU)
- injectors (may need cleaning)
- injector latency? (I just replaced mine with new Deatschwerks 600cc units and the tuner said that the latency adjustment was not fine enough to get a perfect idle)
Also check your idle speed setting - on the auto the idle is only 650RPM
I don't personally believe, with the stock setup at least, that the stagea should idle any other than brilliantly. Mine did, and with the large aftermarket injectors now fitted it is not horrible, only slightly rough.
Edited by DaveB
acceleration is still fine boosts fine and still maintains power (besides a drop between second and third every now and then) i had my plugs changed but the same place as stated but these guys are total muppets and i also suspect them to have stolen stuff from my car when it went down there for a quote after being stolen but thats neither here nor there, i have suspected the idel control unit to be playing up and or the o2 sensor, but i just need to take it to a family mechanic and he'll go completely over it as its soon to go over the pits to get her back on the road due to those kents that stole it, but thanks for the help guys have a day off wednesday and might have a little tinker around and see what i come up with.
Cheers boys
    • No. GKTech arms have spherical bearings in them. No bushes. You will not need bushes for those arms. The sphericals are a bit of a maintenance nightmare. I have replaced all of mine several times in the 5 or so years I've had them, and I have the arms out regularly to clean and lube the balls. Worth the pain on an R32, because the standard arm design is trash. If you need the camber adjustment, there are other options (than the GKTech ones), although I would still lean towards and prefer the GKTech ones, even with the maintenance load of the sphericals. The caster adjustment is also highly valuable, allowing for setting the car up to drive straight. There are a million options for these, including the GKTech ones. I've had Tein rods on mine for 20 years and the balls are much less trouble in that location. Never given me a moment's pain. All positives, no negatives. I consider them compulsory.
    • Lol yeah I ordered the clips mentioned and as far as the amayama diagrams go i think thats all I'll need. Fogured id ask, sometimes people's first hand experience doesnt always match up to diagrams haha, i guess I'll wing it and worse comes to worse I'll just deal with it as I go
    • Thanks for all that information I appreciate it. To answer your questions: - Yep that's what I mean. These guys are professional painters to so I must be missing something. It's a bit hard to explain. - With the primer landing on clearcoat, I make sure that the surrounding clearcoat is scuffed to 240 grit as my epoxy primer says that I only need to sand the area to 240 grit. - Yeah so similar to the first question, assuming that the paint landed on the unscuffed clearcoat because I've seen that happen. - Yep I want to prep the surface in that order. Only reason because epoxy primer will protect it from rust and I need that atm with this crappy Sydney weather. I think I was worried about time, if I try to put the filler down but screw it up somehow and I don't have time to sand it off and reapply it then need to put primer later that it might start to rust again so I wanted to apply the primer as quick as possible to not deal with rust.  - I just deleted some answers, I just realised after watching a video and what you said about looking at the data sheet, that I need to read the data sheet on the specific filler I'm using. It's possible now that I put epoxy primer first was a waste of time and need to go to bare metal lol
    • I did. I went to a suspension guy and he told me because I don't have adjustable camber arms it's the reason why my car veers towards the left if I take my hands off the wheel but if I drive my other every day car and take my hands off the steering wheel it goes completely straight. I think it's common with Skyline's. In order to fix the problem, I likely need gktech camber arms then nismo bushes since I have poly bushes atm, then a wheel alignment after that. With my car if I take my hands off the steering wheel on a really bumpy road before stopping at a light I have to hold my steering wheel somewhat tight otherwise my car will legit just go completely in the other direction quite quickly and I'll slam into something lol instead of stopping straight. I Believe this YouTuber had the same issue and fixed it with gktech arms. At timestmap 6:05 he talks about how the car doesn't veer anymore after installing these arms.
    • hello! does anyone have a schematic that shows how to test the blower motor resistor for the vac system? i believe the part# is 27761-15U00. I think the resistor is toast, but would like to be able to test it somehow before i embark on the journey to find a new one. cheers! 27761-15U00
