Jsai (Js Auto Imports) Josh - Bad Experience Discussion
Hey All,
Recently bought parts off Josh (Z tune style front bar & skirts to fit GTT) - and I paid him immediately and even checked up to see if payments had cleared. Before the payments had cleared, communication with josh was excellent, he was very fast in supplying Bank account details that's for sure. However as soon as payments had cleared, I asked Josh when the parts would arrive (in Melbourne) - he stated 6 days max. 3 to make, 3 to post.
I thought this was brilliant. Yet following the 6 days, nothing. I couldn't start repairs on my car until the front bar arrived - and I had stressed the importance of time to Josh because I has made an appointment with my panel beater. So I texted and asked him about what was going on - no reply. After multiple calls and text msgs - no reply. So I called JapWarehouse (Josh supplies them) to call Josh for me. They contact him, and promise me the parts will arrive in a few days (despite it has already been 2 weeks delayed). The few days past and nothing AGAIN - I call JapWarehouse and they now say he won't pick up THEIR calls. A month later, not a call or a text.
Very sick and tired of these bullshit people who run "businesses" - if you can't follow through with your work, then don't make them.
Anyone else sharing the same experience?
The sad thing is, Josh's business started off in 2007 claiming to oppose this type of experience - claiming he himself was sick of dealing with no communication and no parts. It didn't take you long to become the same thing Josh.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
