Make it happen eh
well here's what i've got so far
R33 Engine Oil
http://www.skylinesaustralia.com/forums/sh...highlight=sciby
R33 Head Unit
http://www.skylinesaustralia.com/forums/sh...highlight=guide
R32 Gearbox oil
http://www.skylinesaustralia.com/forums/sh...ead.php?t=30665
Painting Brake Calipers
Bedding in Brake Pads
Removing Dash in R33
http://www.skylinesaustralia.com/forums/sh...ead.php?t=31550
Pic is here
http://www.skylinesaustralia.com/fo...achmentid=10054
R33 Heater Unit removal
R33 Brake Pad Change
R33 Front shocks (no pics)
R32 Headlight Globes (no pics)
R33 Boost Gauge (no pics)
Removing R33 Turbo
http://www.skylinesaustralia.com/forums/sh...ead.php?t=22118
VL Turbo onto RB25DET
http://www.skylinesaustralia.com/forums/sh...ead.php?t=30556
Dual headlight/highbeam Mod
http://www.skylinesaustralia.com/forums/sh...25&pagenumber=1
Removing door trim R33 (no pics)
http://www.skylinesaustralia.com/forums/sh...ead.php?t=23642
Removing R33 front bar S1 (no pics)
http://www.skylinesaustralia.com/forums/sh...ead.php?t=15177
Removing R33 front bar S2 (no pics)
http://www.skylinesaustralia.com/forums/sh...hread.php?t=761
Removing rear seats R33 (no pics)
http://www.skylinesaustralia.com/forums/sh...read.php?t=3654
https://www.sau.com.au/forums/topic/34833-diy-section/#findComment-697812
Good work ferretting them out :D somebody had to do it, good work.. I'll add:
Here is the original thread about the calipers, but the photos may have been lost.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=19736
Here is a very quick one on spark plug replacement, although I believe there was another out there. Unfortunately its not the first post so you may have to pull it out. I'll edit it over time to improve it, as I realise it is missing photos.
http://www.skylinesaustralia.com/forums/sh...32&postcount=41
Stereo Installation guide for R33:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=12956
Some valuable advice regarding R33 exhausts
http://www.skylinesaustralia.com/forums/sh...ead.php?t=33991
My fav :D fuel pump 910 installs:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=23957
The original..with some other info on fuel pump installs from others:
http://www.skylinesaustralia.com/forums/sh...00&page=1&pp=25
https://www.sau.com.au/forums/topic/34833-diy-section/#findComment-698380
great..we're missing a stack of photos :( I have mine on my hdd somewhere, but its going to require quite a bit of time and motivation to upload them all again
they should all still be here.. i'll see if i can fix it.
https://www.sau.com.au/forums/topic/34833-diy-section/#findComment-700655
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
