Buy a BMX bike, insert cardboard in wheel spokes, and pretend your on a motorbike...........
+1
you obviously don't deserve to have a licence or be behind the wheel of a car. people like you are the reason skyline owners get targetted by the police.
  • Like 2
Hi guys, just lost my licence again for the 3rd time on my red p's, so im gonna sell the 34 gtt and get a new car and buy a house
any ideas for a new car for under 10k will be greatttt!
Cheers
Stuff the car and get a bike,
Honda CBR :D
I got dicked again, lost 6points.. sighh.. i decided i'm keeping the car.
Thanks for the replies, you're all a bunch of 50 yr olds who seriously need to loosen the f**kup.
If you all do drive a high powered car on the street and don't "speed" or do anything.
Go get a corolla. I don't see the point of having a skyline when you can't enjoy it..
  • Nope 9
god you're such a tool
  • Like 1
that's why we go to race tracks... i get to keep my license, and enjoy my car 10x more than some douchebag racing hibibi's on the streets
  • Like 2
dicked for?
buy one of those na vtec civics
those things go hard
We all speed every now and then, some just use common sense when not to speed (ie when you have shit all demerit points left).
Having license is not a right, it's a privilege.
  • Like 1
3times and still havent learnt your lesson....
this is all you could be trusted with...
This has to be the reply of the year!
OP, you've lost your license THREE TIMES and you're getting offended because people are making fun of you? Don't you think you need to change your attitude towards driving? It's one thing to enjoy a car, it's a completely different thing to lose your licence three times. On your red p's. Meaning that you haven't been driving for very long and you've already lost your licence three times.
By the way, if you've lost your licence, why do you need to get another car? Do you plan on driving without a licence?
get a commodore and go on there forums ou will be praised for being able to loose your license so quick so many times!!!
This pretty much sums it up.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
