Buy a BMX bike, insert cardboard in wheel spokes, and pretend your on a motorbike...........
+1
you obviously don't deserve to have a licence or be behind the wheel of a car. people like you are the reason skyline owners get targetted by the police.
  • Like 2
Hi guys, just lost my licence again for the 3rd time on my red p's, so im gonna sell the 34 gtt and get a new car and buy a house
any ideas for a new car for under 10k will be greatttt!
Cheers
Stuff the car and get a bike,
Honda CBR :D
I got dicked again, lost 6points.. sighh.. i decided i'm keeping the car.
Thanks for the replies, you're all a bunch of 50 yr olds who seriously need to loosen the f**kup.
If you all do drive a high powered car on the street and don't "speed" or do anything.
Go get a corolla. I don't see the point of having a skyline when you can't enjoy it..
  • Nope 9
god you're such a tool
  • Like 1
that's why we go to race tracks... i get to keep my license, and enjoy my car 10x more than some douchebag racing hibibi's on the streets
  • Like 2
dicked for?
buy one of those na vtec civics
those things go hard
We all speed every now and then, some just use common sense when not to speed (ie when you have shit all demerit points left).
Having license is not a right, it's a privilege.
  • Like 1
3times and still havent learnt your lesson....
this is all you could be trusted with...
This has to be the reply of the year!
OP, you've lost your license THREE TIMES and you're getting offended because people are making fun of you? Don't you think you need to change your attitude towards driving? It's one thing to enjoy a car, it's a completely different thing to lose your licence three times. On your red p's. Meaning that you haven't been driving for very long and you've already lost your licence three times.
By the way, if you've lost your licence, why do you need to get another car? Do you plan on driving without a licence?
get a commodore and go on there forums ou will be praised for being able to loose your license so quick so many times!!!
This pretty much sums it up.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
