Ok since my car is bat shit boring and I wanna get back into sliding again after never owning a 6cyl in my
life Id like some opinions on a best suited turbo for the internally stock rb25det. Basically all I aim for
is a cost effective song engine combination that will aid in me sliding like a happy camper once again.
I WILL be using a stock manifold with an external wastegate mod done sponsored by a fellow member 10WRB but
Im still retarded in picking a turbo that would be best suited for wat I want. I have seen a few posts about
a GTX3076 and I do know a 3076 can make 400hp which would be enough for wat I need so Im here for more extra
input befor I lash out and by something to big or to small and Ill end up in tears.
End of the day I wanna be able to bake tyres, have the reliability without goin over the top and to keep it
looking semi stock.
Cheers
Isnt the GT-RS a fairly expensive turbo?
Iv seen a few skyline vary in power from 300 - 400 with these
Id like to keep boost around the 16-18 psi mark if this helps anymore
How much are you wanting to spend? If you're baller, then a Garrett GTX3071R or a Borg Warner EFR7064 would be the way to go - if you're middle of the road then a Garrett GT3076R with internal gate, otherwise something like a Kando Dynamics T67 would probably be pretty nifty for a budget option if they carry on behaving as nicely as people are finding them so far.
Dont wanna fork out anymore then 1800-2000 for a turbo. Just rang MTQ and they are saying that the GTX series will be goin for around the 2k mark
so Ill hang out till they have stock and go from there.
Thats why I gave you a range of options, seeing as you didnt specify a price in the first place. Obviously a GT3076R with internal gate is probably the most suitable option for you.
Nah 2k for just the turbo I was talking about haha.
Manifold, gate, dump is all under control already.
Anything with a GT30 core will bolt straight up to wat I can
get my hands on.
I do like that t67 25g kando turbo aswell but I dont like f**kin around with flanges
n shit cause im far to lazy for that.
I will most likely hang out for either the GTX 3071 or the GTX 3076 and go with either or.
Just had a gander at the Kando Dynamics T67 25g...
Wow lol
Definitely WOW! Just remember that has an aftermarket manifold, external wastegate and runs E85 fuel.
I think the HKS GT2835 Pro S is the best overall turbo out there for a stock RB25 today, 280-290rwkw on 98 with full boost by 3500rpm. Things might change once these GTX turbos come out. Only time will tell.
f**kin wow alright haha.
Yeah see I just wanna be able to bolt it on, ram 18pound through the guts, put fuel in it and away I go.
Obviously Iv missed tuning n shit but you get the point. So ill play the waitin game till these GTX turbos
land here and then do a bit of shopping around, might make up for a late xmas present. If the GTX 3071 can flow
10% more then a GT3076 Id like to see the performance of a GTX3076 .82 on the rb25.
get my hands on.
The Kando T67 comes with a T3 flange so you wouldn't have to change anything :)
Except for your exhaust manifold, external wastegate and dump pipe! Or you have to get some custom piping done to run an external wastegate.
I'd absolutely love to experience a GT2835 and a GT3076R back to back, I went with the GT3076R with the view I might end up going to a built motor and IMHO the GT2835 suits a completely unopened RB25 nicely - but not much more.
    • Solid update, got all the downforces now.  You going to be running aus time attack again? love the jacking solution, spend the dollars on what makes it go fast is best way.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
