Hey guys I've been in the market for a replacement engine for my R33 and the Neo looks like a good option over the S2 but the additional cost is the only thing prohibiting me jumping on it.
I'm not sure if it's the same in Australia but here in New Zealand RB25DET Neo AWD's it seems are sometimes cheaper than both their S1/2/Neo RWD counterparts.
Now this choice for a Neo is obviously for the easy HP gains it boasts over the S1 & 2, so what I'm really curious about is there any difference between the AWD & RWD motors?
Searching has shown that the RWD sump will bolt on fine to the AWD block but are there any hidden differences I'm not aware of like loom, internals etc?
Because I have a spare RB25DET S2 engine (seized) in addition to the one I am removing, lying on my garage floor which I could use for the sump (or any extra parts if need be).
Thanks in advance for your help. Feel free to ask any questions!
Edited by Tyral
https://www.sau.com.au/forums/topic/348376-rb25det-neo-awdrwd-differences/
Different bolt pattern for the sump
so no the rwd sump wont just bolt on
I read that the AWD block has both bolt patterns unlike the RWD which only has 1? Here's an example of a thread I found here.
AFAIK the AWD blocks have provision for RWD sumps too.
The only major difference off the top of my head between RWD and AWD Neos is that the AWD Stagea doesn't have traction control and most are auto's. This means the pinouts on the ECU are different and a 34GTT ECU won't work. Not a drama as the Neo Stag ecu's can be NIStuned.
mate has a 32 with a 2wd neo in it
the car does runs fine with a stagea ecu or a gtt ecu in it . gtt ecu throws error 44 and 46 . 44 being the cable between abs comp and ecu is faulty ( does not throw engine light ) 46 being traction controll motor voltage being to low . (does turn engine light on)
stagea ecu runs sweet as
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
